Salta al contenuto principale
How to Repair a Patio Solar Light
Miguel Antonio Gonzales
Miguel Antonio Gonzales e 2 altri collaboratori
Ultimo aggiornamento il May 30, 2024
10 minuti
Moderato
Introduzione
Vai al passo 1
Has your solar patio light stopped working? Fixing a patio solar light circuit board is fast and easy when you have the right tools. Most commercial patio solar lights are relatively cheap items used as decor for gardens and front yards, and under extreme heat conditions wires can melt off of the circuit board leaving the light faulty and useless, but fixing it saves another piece of plastic and metal from landfills and saves the owner a couple of bucks!
Cosa ti serve
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. How to Repair a Patio Solar Light, How to Repair a Patio Solar Light: passo 1, immagine 1 di 1
    • Disassemble the circuit box using a Phillips screwdriver.
  2. How to Repair a Patio Solar Light: passo 2, immagine 1 di 1
    • Using a multimeter, put the black wire in the COM port, and the red wire into the far right port. Set the switch to 20 volts DC.
  3. How to Repair a Patio Solar Light: passo 3, immagine 1 di 1
    • Remove battery from the port.
    • Check both ends of the battery with the multimeter.
    • The red prong touches the negative side, and the black prong touches the positive side of the battery.
  4. How to Repair a Patio Solar Light: passo 4, immagine 1 di 1
    • Ensure that the multimeter screen shows a number that matches or is greater than the voltage of the battery. If not, replace the battery.
    • Check the circuit board for detached, or loosely connected wires.
  5. How to Repair a Patio Solar Light: passo 5, immagine 1 di 3 How to Repair a Patio Solar Light: passo 5, immagine 2 di 3 How to Repair a Patio Solar Light: passo 5, immagine 3 di 3
    • Use a soldering iron at 400 Celsius to melt your soldering wire. Gather a droplet on the tip of the soldering iron, and use the drop to reattach the disconnected wire back onto the circuit board.
    • CAUTION: Don't handle metal parts of the soldering iron without proper gloves and protection.
  6. How to Repair a Patio Solar Light: passo 6, immagine 1 di 1
    • Turn your solar light back on before reassembling to test if it’s working properly.
    • When the light turns on, reassemble your solar light.
Conclusione
Membro da: 02/20/24
133 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 56
Tutti i Tempi: 270
