Introduzione
Want to upgrade or repair the old car stereo on a Chevy Tracker? Don't feel intimidated because this guide will help you with the first process of removal!
Cosa ti serve
First, you must disconnect the negative end of the car battery.
Open the hood of your car and locate the battery.
Look for the negative end of your battery. It is usually indicated with a minus sign next to it.
Unplugging the connections, except for the multicolored group of wires. All are located on the back of stereo should be as simple as pulling on them.
"To remove the group of wires", follow the wires until you reach a connector and unplug the connector.
The thick, metal wire connecting to the radio antennae can be easily removed by pulling on it.
Following the steps in reverse will reinstall your car stereo. Different car stereos might require extra connections to be installed.
Altre 4 persone hanno completato questa guida.
