Salta al contenuto principale
How to Remove Underwires from a Bra
Farzana Jalal
Farzana Jalal e un altro collaboratore
Ultimo aggiornamento il 29 set 2021
10 - 20 minuti
Facile
Introduzione
Vai al passo 1
Do you have an underwired bra that doesn’t fit quite right? Or, a broken underwire that is poking you? In either case, follow this guide to remove the underwire from your bra and continue using your favorite bra for several more years.
This guide will help to remove the underwires which will prevent you from feeling any more discomfort. In the end, you will still have a bra it will feel brand new again!
Removing the underwires is not difficult. It is a quick fix and the skill can be applied to other similar fixes needed for apparel. A seam ripper is ideal to quickly safely and neatly extract the underwires from your bra, but this project can be accomplished with any similar alternative tool that is sleek and sharp.
Cosa ti serve
Ricambi
Strumenti
  1. How to Remove Underwires from a Bra, How to Remove Underwires from a Bra: passo 1, immagine 1 di 1
    • Take out bra that requires underwire removal.
  2. How to Remove Underwires from a Bra: passo 2, immagine 1 di 1
    • Lay it face down.
    • Meaning the inside of bra faces up now.
  3. How to Remove Underwires from a Bra: passo 3, immagine 1 di 2 How to Remove Underwires from a Bra: passo 3, immagine 2 di 2
    • Identify the area that covers the underwires by feeling where the solid metal underwire is.
  4. How to Remove Underwires from a Bra: passo 4, immagine 1 di 1
    • Identify the hem (outlined by the red box in the picture) of the underwire lining for both of the cups at each end.
    • To know the anatomy of a bra, click here.
  5. How to Remove Underwires from a Bra: passo 5, immagine 1 di 3 How to Remove Underwires from a Bra: passo 5, immagine 2 di 3 How to Remove Underwires from a Bra: passo 5, immagine 3 di 3
  6. How to Remove Underwires from a Bra: passo 6, immagine 1 di 3 How to Remove Underwires from a Bra: passo 6, immagine 2 di 3 How to Remove Underwires from a Bra: passo 6, immagine 3 di 3
    • Use the seam ripper to rip the stitches of the hem by going under the thread. This increases the chance of precision and prevents injury to fingers.
    • Make sure to hold the seam ripper with your index finger pointing outwards and aligning it with the sharp side of the seam ripper at the bottom (look at the third picture in this step).
    • If you are a minor, recommended having adult supervision as sharp object is involved.
  7. How to Remove Underwires from a Bra: passo 7, immagine 1 di 3 How to Remove Underwires from a Bra: passo 7, immagine 2 di 3 How to Remove Underwires from a Bra: passo 7, immagine 3 di 3
    • Push the underwire up through the open hem until it pokes out.
    • Then pull the underwire out from the hemmed area.
  8. How to Remove Underwires from a Bra: passo 8, immagine 1 di 1
    • Repeat on the other cup by redoing steps 6-7. You should now be left with 2 underwires that were previously in your bra.
    • Optional: If you want to stitch up the hem check out this underwire bra repair that can be applied here.
Linea Traguardo
1Commento della guida
What can I do with the removed underwires? Ideas needed ☺️
ruth shaw - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 67
Tutti i Tempi: 12,691
