How to Rekey a Kwikset Deadbolt Lock
Introduzione
Vai al passo 1This guide will help with the process of Re-keying a Deadbolt Lock in your door. For purposes of clarity, this guide has the deadbolt out of the door so each part can be seen with as much detail as possible. Re-keying a lock is useful for improving the security of a home and it can replace previous keys that you have lost or may have been unknowingly copied. Many steps of this process contain small parts, so proceed with caution in this fix.
Note: This re-keying was performed on a Kwikset deadbolt, but the procedure should be the same for most brands.
Cosa ti serve
Remove the mounting screws from the thumb-turn side of the lock assembly using a Phillips screwdriver.
Remove the springs carefully with tweezers or pliers and set the springs aside as they will need to be put back in during reassembly.
Never do what this says and pull the springs out! Chances are you'll never get it back together correctly. there's a tool, i think called a "following tool", which is a plastic cylinder that pushes the cylinder out and keeps the springs in place from the inside. find some other instructions because this is not how you do it.
To reassemble your device, follow these instructions in reverse order from step 8.
Altre 17 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti6Commenti sulla guida
worked according to the instructions
Huh?? What do you do after the last instruction?
Follow the instructions in reverse order starting from step 8.
Worked exactly as described. Watch those springs! They fly out easily, and are prone to bend when reinstalled.
Note: if you have a following tool (that's what it's called), you do not need to take off the top plate (which may be more delicate than the retaining clip). Alternatively, you can do something similar in not removing the retaining clip and just dumping all the pins out through the top, and using a key gauge (relatively cheap online) to determine the correct pins.
