Salta al contenuto principale
How to Prevent a Run or Tear in Tights from Spreading
Audrey Fremier
Audrey Fremier e 2 altri collaboratori
Ultimo aggiornamento il June 25, 2015
3 - 5 minuti
Molto facile
Introduzione
Vai al passo 1
This guide explains how to quickly and simply reduce the spreading of a hole in nylon tights by applying nail polish. Nail polish is a quick drying substance. If administered to the edges of a run,it will harden the frayed edges and prevent the run from expanding further into the nylon.
Cosa ti serve
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. How to Prevent a Run or Tear in Tights from Spreading, Run or Tear in Tights: passo 1, immagine 1 di 2 How to Prevent a Run or Tear in Tights from Spreading, Run or Tear in Tights: passo 1, immagine 2 di 2
    • Put the ripped tights on for easier repair, or leave them on if you’re already wearing them.
    • Gather clear nail polish and a pair of scissors.
  2. How to Prevent a Run or Tear in Tights from Spreading: passo 2, immagine 1 di 1
    • Locate all potential runs or directions that the rip can expand.
    • Runs will not usually expand horizontally, but be sure to check both vertical ends of the run.
  3. How to Prevent a Run or Tear in Tights from Spreading: passo 3, immagine 1 di 1
    • Gently tug the tights away from your skin to prevent the nail polish from affixing to your body.
  4. How to Prevent a Run or Tear in Tights from Spreading: passo 4, immagine 1 di 2 How to Prevent a Run or Tear in Tights from Spreading: passo 4, immagine 2 di 2
    • Brush a dollop of clear nail polish on all potential runs.
    • Small runs will require just a dab of nail polish while larger holes may require a thin coat.
    • Repeat these steps to all potential runs and loose threads.
  5. How to Prevent a Run or Tear in Tights from Spreading: passo 5, immagine 1 di 1
    • Once the nail polish has dried, you may cut any hanging pieces of thread.
    • The nail polish will take about 1 minute to dry.
    • Be sure to complete this step after applying the nail polish and letting it dry or a new run will form.
Conclusione
These steps can save a pair of tights from becoming too tattered for normal use.
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 12-1, Green Winter 2015 Membro di Cal Poly, Team 12-1, Green Winter 2015
CPSU-GREEN-W15S12G1
6 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 44
Ultimi 30 Giorni: 134
Tutti i Tempi: 40,549
