Salta al contenuto principale
How to Patch a Hole in a Kote
Dawn Lattin
Dawn Lattin e un altro collaboratore
Ultimo aggiornamento il August 16, 2023
25 - 30 minuti
Moderato
Introduzione
Vai al passo 1
With regular use, kote, the gauntlets worn by practitioners of kendo, or Japanese fencing, will wear down where the fingertips grip the sword. Suppliers of this specialized athletic equipment will repair these holes, sometimes for approximately $24.00 + shipping and handling both ways. This will leave the martial artist without equipment and unable to practice, and can also be a drain on the wallet. These holes can be quickly and affordably fixed with a leather patch made from an inexpensive polishing sham found at most auto supply stores, leaving the martial artist with no excuse to miss out on practice or risk painful splinters or bruises to their fingers.
  1. How to Patch a Hole in a Kote, How to Patch a Hole in a Kote: passo 1, immagine 1 di 1
    • Use the ruler to measure the hole, and add a 1/4 to 1/2 inch buffer on all sides.
  2. How to Patch a Hole in a Kote: passo 2, immagine 1 di 1
    • Use the ruler and pen to create guiding lines for these measurements directly on the backside of the leather patch.
  3. How to Patch a Hole in a Kote: passo 3, immagine 1 di 1
    • Use the scissors to cut along the guiding lines.
  4. How to Patch a Hole in a Kote: passo 4, immagine 1 di 1
    • Center the leather patch over the hole and pin it in place.
  5. How to Patch a Hole in a Kote: passo 5, immagine 1 di 1
    • Cut approximately 30 inches of thread and thread 15 inches through the needle.
    • Tie the two ends of the thread into a square knot by creating a loop, drawing the ends through the loop, and pulling it tight.
  6. How to Patch a Hole in a Kote: passo 6, immagine 1 di 2 How to Patch a Hole in a Kote: passo 6, immagine 2 di 2
    • After drawing the thread through the patch from below, about 1/4 inch from the edge, use the thimble to push the needle through the kote, just outside the patch.
    • Use the pliers to pull the needle through the kote and leather.
    • Repeat the process all around the patch until you return to the first stitch.
  7. How to Patch a Hole in a Kote: passo 7, immagine 1 di 3 How to Patch a Hole in a Kote: passo 7, immagine 2 di 3 How to Patch a Hole in a Kote: passo 7, immagine 3 di 3
    • Knot the final stitch in place by running the needle under the first stitch.
    • Pull the thread to create a loop, and run the needle through the loop towards you.
    • To hide the knot, run the needle beneath the patch and pull the thread through, cutting it close to the patch.
  8. How to Patch a Hole in a Kote: passo 8, immagine 1 di 1
    • You have successfully patched the hole in your kote.
Conclusione
To patch your kote, follow these steps in chronological order.
Dawn Lattin
Membro da: 06/11/21
157 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 31
Tutti i Tempi: 1,000
