Salta al contenuto principale
How to Open Logitech Harmony 1100
Keegan Williams
Keegan Williams e 4 altri collaboratori
Ultimo aggiornamento il February 18, 2025
2 minuti
Facile
Foto Azione
Introduzione Migliore
Studente al lavoro
Cosa ti serve
Strumenti
Mostra di più…
  1. How to Open Logitech Harmony 1100, How to Open Logitech Harmony 1100: passo 1, immagine 1 di 2 How to Open Logitech Harmony 1100, How to Open Logitech Harmony 1100: passo 1, immagine 2 di 2
    • Remove battery cover, pushing down on circled areas and pushing outward
    • Remove battery by lifting up on corner exposed by indent in case
  2. How to Open Logitech Harmony 1100: passo 2, immagine 1 di 1
    • Use a J0 screwdriver head
    • Remove 3 screws from battery compartment
  3. How to Open Logitech Harmony 1100: passo 3, immagine 1 di 2 How to Open Logitech Harmony 1100: passo 3, immagine 2 di 2
    • Open connector port on side
    • Remove screw with PH00 screwdriver head
  4. How to Open Logitech Harmony 1100: passo 4, immagine 1 di 3 How to Open Logitech Harmony 1100: passo 4, immagine 2 di 3 How to Open Logitech Harmony 1100: passo 4, immagine 3 di 3
    • Use plastic opening tool to pry at the open slits on the side.
    • One or two silver foam cubes may pop out of the device. These belong in the slots shown in the third picture. They do not need to go back until reassembly.
    • Also the plastic connector door will fall off. It will need to be put back upon reassembly.
Conclusione
Ohio State, Team 1-5, Garvin Spring 2016 Membro di Ohio State, Team 1-5, Garvin Spring 2016
OSU-GARVIN-S16S1G5
3 Membri
3 Guide realizzate
1Commento della guida
Will changing the battery reset the settings within the remote?
wiboman AT gmail DOT com
Wibo Lammerts - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,473
