Salta al contenuto principale
How to Install an HID Conversion Kit
Eric Wu
Eric Wu e un altro collaboratore
Ultimo aggiornamento il 12 mag 2015
1 - 2 ore
Moderato
Guida fornita dalla comunità
Introduzione
Vai al passo 1
If you're tired of your halogen headlights or fog lights and want to upgrade to something with a better output, try installing an HID Conversion Kit.
Cosa ti serve
  1. How to Install an HID Conversion Kit, Headlights: passo 1, immagine 1 di 2 How to Install an HID Conversion Kit, Headlights: passo 1, immagine 2 di 2
    • Open the hood.
    • Locate the back of the headlights and remove the bolts holding the headlight housing.
  2. How to Install an HID Conversion Kit: passo 2, immagine 1 di 1
    • Unplug the stock harness and remove the headlights.
  3. How to Install an HID Conversion Kit: passo 3, immagine 1 di 2 How to Install an HID Conversion Kit: passo 3, immagine 2 di 2
    • Remove battery negative terminal.
    • Remove headlight cover and remove factory halogen bulb.
  4. How to Install an HID Conversion Kit: passo 4, immagine 1 di 1
    • Take out the HID bulb from the plastic shell and remove the circular plastic piece.
    • Remember not to touch the HID bulb glass!
    • If you accidentally touch it, you can clean it with some rubbing alcohol.
  5. How to Install an HID Conversion Kit: passo 5, immagine 1 di 2 How to Install an HID Conversion Kit: passo 5, immagine 2 di 2
    • Screw in the HID bulb back into the headlight housing.
    • Connect the wires of the HID bulb to the ballast and then connect the HID ballast back to the stock harness.
  6. How to Install an HID Conversion Kit: passo 6, immagine 1 di 1
    • Before you mount the ballast, test the HID light to make sure it lights up.
    • If not, turn the adapter wire 180 degrees.
    • Mount the HID ballast with zip ties.
  7. How to Install an HID Conversion Kit: passo 7, immagine 1 di 3 How to Install an HID Conversion Kit: passo 7, immagine 2 di 3 How to Install an HID Conversion Kit: passo 7, immagine 3 di 3
    • Put everything (like the headlight housing) back.
    • Enjoy!
Conclusione
Enjoy your new HID Conversion Kit and upgraded headlights or fog lights.
Altre 6 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
Eric Wu
Membro da: 01/21/15
3.396 Reputazione
23 Guide realizzate
1Commento della guida
Tradução em português sff.
Dall Costa - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 92
Tutti i Tempi: 17,843
