Salta al contenuto principale
How to Fix the Worx Pegasus Workbench lower tray
RodCastler
RodCastler e un altro collaboratore
Ultimo aggiornamento il March 28, 2024
8 - 15 minuti
Molto facile
Pallini!
Guida fornita dalla comunità
Introduzione
Vai al passo 1
The lower tray on the WORX Pegasus is a substantial part of the assembly as it prevents the legs of the bench from spreading apart while adding stability.
Sometimes these trays become accidentally detached from each other, either partially or completely, preventing you from fully opening the bench.
Fortunately, there is an easy and permanent fix for this.
Cosa ti serve
Ricambi
  • Zip Ties (Small)
Strumenti
Mostra di più…
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. How to Fix the Worx Pegasus Workbench lower tray, Re-assemble per factory: passo 1, immagine 1 di 2 How to Fix the Worx Pegasus Workbench lower tray, Re-assemble per factory: passo 1, immagine 2 di 2
    • If yours became detached, make sure you begin by manually re-assembling the tray as it came from factory.
  2. How to Fix the Worx Pegasus Workbench lower tray, Drill through the hinge: passo 2, immagine 1 di 2 How to Fix the Worx Pegasus Workbench lower tray, Drill through the hinge: passo 2, immagine 2 di 2
    • Drill a small hole, the smallest possible but large enough to allow a zip tie to go through. I used a 1.5mm drill bit.
  3. How to Fix the Worx Pegasus Workbench lower tray, Route a Zip Tie: passo 3, immagine 1 di 2 How to Fix the Worx Pegasus Workbench lower tray, Route a Zip Tie: passo 3, immagine 2 di 2
    • Route a Zip Tie through the hole you just drilled and around the hinge barrel.
    • Cut the excess with scissors or wire cutters.
    • Do this procedure at least on two hinges: the leftmost and rightmost. For best results, address all six hinges.
  4. How to Fix the Worx Pegasus Workbench lower tray, Enjoy your reliable workbench: passo 4, immagine 1 di 1
    • If done correctly, the tray is not going to fail again.
    • This fix also adds a little bit more strength to the lower tray.
    • Enjoy!
Linea Traguardo
RodCastler
Membro da: 10/29/22
373 Reputazione
2 Guide realizzate
Un commento
Nice job. Only critique is a better or close up of where you drill the holes for the zip ties. Hard to see from your pics. I figured it out and added all 6 to my hinges as that tray falls off non-stop. Thanks! I also added 4 other zip ties to the 4 small exterior holes on the outside of the tray that lock the perimeter attachment hinges into place as well.
Ray Wright - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 42
Tutti i Tempi: 502
