Salta al contenuto principale
How to Fix an Overwound Music Box
Gaurangi Sawant
Gaurangi Sawant e 2 altri collaboratori
Ultimo aggiornamento il May 3, 2024
10 - 20 minuti
Facile
Introduzione
Vai al passo 1
The extensive use of a music box and winding the main spring excessively will lead it to fail. This failure is caused because the music box mechanism gets jammed, and then, you are no longer able to enjoy its beautiful tunes.
However, the music box that you have loved and cherished over the years can still be salvaged. This guide will help restore your music box to mint condition with some easy-to-do steps that will assist the restoration of the mechanism.
With minimal effort your music box will resume entertaining you with its beautiful tunes.
Cosa ti serve
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. How to Fix an Overwound Music Box, How to Fix an Overwound Music Box: passo 1, immagine 1 di 3 How to Fix an Overwound Music Box, How to Fix an Overwound Music Box: passo 1, immagine 2 di 3 How to Fix an Overwound Music Box, How to Fix an Overwound Music Box: passo 1, immagine 3 di 3
    • Use a Phillips #0 screwdriver to unscrew the screws at the base of the music box.
    • Remove the outer casing and isolate the mechanism.
  2. How to Fix an Overwound Music Box: passo 2, immagine 1 di 2 How to Fix an Overwound Music Box: passo 2, immagine 2 di 2
    • Gently wipe the mechanism with a cloth to get rid of any settled dust particles.
    • Make sure you wipe all the open and accessible surfaces of the mechanism.
    • Be extremely careful when cleaning the comb and the drum. The comb is delicate and can break when too much pressure is applied. The threads of the cloth can get stuck in the pins of the drum.
  3. How to Fix an Overwound Music Box: passo 3, immagine 1 di 2 How to Fix an Overwound Music Box: passo 3, immagine 2 di 2
    • Slowly turn the winding key in the opposite direction to release the tension built-up in the spring.
  4. How to Fix an Overwound Music Box: passo 4, immagine 1 di 2 How to Fix an Overwound Music Box: passo 4, immagine 2 di 2
    • Tap the base of the mechanism a few times to release the governor assembly.
  5. How to Fix an Overwound Music Box: passo 5, immagine 1 di 2 How to Fix an Overwound Music Box: passo 5, immagine 2 di 2
    • Gently push the governor fan with your fingertip to assist its spin movement.
  6. How to Fix an Overwound Music Box: passo 6, immagine 1 di 3 How to Fix an Overwound Music Box: passo 6, immagine 2 di 3 How to Fix an Overwound Music Box: passo 6, immagine 3 di 3
    • Use a toothpick to reach the flywheel.
    • Push the toothpick forward to spin the flywheel and assist its rotation.
  7. How to Fix an Overwound Music Box: passo 7, immagine 1 di 2 How to Fix an Overwound Music Box: passo 7, immagine 2 di 2
    • Using a narrow nozzle, spray some WD-40 on the spring housing gear and the governor.
    • The nozzle is pointed at the spring housing gear in the first photo, and in the second photo the nozzle is pointed at the governor.
    • In case you don't have a narrow nozzle, you can add a few drops of WD-40 using any other small quantity dropper.
  8. How to Fix an Overwound Music Box: passo 8, immagine 1 di 1
    • Keep the music box playing for a few minutes after it restarts.
Conclusione
Altre 11 persone hanno completato questa guida.
19Commenti sulla guida
Very clear instructions. However my music mechanism has glue keeping it firmly to the base of porcelain box. How to release it so I can follow your instructions to repair it. It's a Lenox figurine of baby sitting & spinning on a Christmas gift. White with gold accents
Thank you
Beachbabe - Replica
You should be able to loosen the glue with denatured alcohol, acetone or a heat gun, or a hair dryer if you don't have one. Then gently remove the music box. When your finished you can reglue the music box into the figurine with a household glue like E6000.
Kathy -
Mine is in a stuffed animal and i dont want to have to break the plush to fix it
Idk - Replica
With stuffed animals, use a seam ripper to undo the threads of where the fur is sewn, then sew it back together after the repair
Olivia's Furby Repairs -
I would add that unless it is a swiss mechanism you would be better off replacing. I do not usually restore these plastic ones.
musicboxman63 -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 35
Ultimi 7 Giorni: 275
Ultimi 30 Giorni: 1,343
Tutti i Tempi: 74,288
