Salta al contenuto principale
How to Fix a Sticking Deadbolt
Elizabeth Nesler
Elizabeth Nesler e 3 altri collaboratori
Ultimo aggiornamento il 18 mag 2016
45 minuti - 1 ora
Moderato
Introduzione
Vai al passo 1
A sticking deadbolt is a common nuisance for homeowners. It can be caused by debris, weather, and general wear and tear. This guide will instruct users how to repair a sticking deadbolt. Fortunately, this is an intermediate fix and the estimated time to complete this repair is thirty to forty-five minutes.
Cosa ti serve
Strumenti
Mostra di più…
  1. How to Fix a Sticking Deadbolt, How to Fix a Sticking Deadbolt: passo 1, immagine 1 di 2 How to Fix a Sticking Deadbolt, How to Fix a Sticking Deadbolt: passo 1, immagine 2 di 2
    • Use a Phillips screwdriver to remove both of the ¾-inch screws from the strike plate.
  2. How to Fix a Sticking Deadbolt: passo 2, immagine 1 di 2 How to Fix a Sticking Deadbolt: passo 2, immagine 2 di 2
    • Remove both of the 2.5 inch mounting screws from the lock cylinder.
  3. How to Fix a Sticking Deadbolt: passo 3, immagine 1 di 1
    • After all four screws have been taken out, slide the latch of the deadbolt out of the door frame.
  4. How to Fix a Sticking Deadbolt: passo 4, immagine 1 di 2 How to Fix a Sticking Deadbolt: passo 4, immagine 2 di 2
    • Spray GumOut parts cleaner at an angle into the latch of the deadbolt.
    • Use a rag to clean and dry off latch.
    • We suggest using GumOut cleaning solutions, which is available at most home improvement stores.
  5. How to Fix a Sticking Deadbolt: passo 5, immagine 1 di 1
    • Spray GumOut parts cleaner into the key cylinder to lubricate chamber.
  6. How to Fix a Sticking Deadbolt: passo 6, immagine 1 di 2 How to Fix a Sticking Deadbolt: passo 6, immagine 2 di 2
    • Insert dry powdered graphite into the key cylinder of the deadbolt.
    • Place the key into the cylinder to lubricate and clean the chamber.
    • If it is difficult to turn the key, then apply more dry powdered graphite into the cylinder.
  7. How to Fix a Sticking Deadbolt: passo 7, immagine 1 di 2 How to Fix a Sticking Deadbolt: passo 7, immagine 2 di 2
    • Apply the dry powdered graphite to the latch of the deadbolt.
    • Use a rag to remove excess dry powdered graphite from the latch.
  8. How to Fix a Sticking Deadbolt: passo 8, immagine 1 di 1
    • Slide the latch of the deadbolt back into the door frame.
  9. How to Fix a Sticking Deadbolt: passo 9, immagine 1 di 3 How to Fix a Sticking Deadbolt: passo 9, immagine 2 di 3 How to Fix a Sticking Deadbolt: passo 9, immagine 3 di 3
    • Take the lock cylinder and the 2.5 inch mounting screws and insert them through the latch of the deadbolt.
    • Then mount the key cylinder on the screws.
    • Use a Phillips screwdriver to tighten the 2.5 inch mounting screws and secure the deadbolt to the frame.
    • The cylinder should be mounted on the outside of the doorframe.
  10. How to Fix a Sticking Deadbolt: passo 10, immagine 1 di 1
    • Use a Phillips screwdriver to screw in both of the ¾-inch screws back into the strike plate.
Conclusione
After following this fast fix guide, the sticking deadbolt should be fixed.
Altre 5 persone hanno completato questa guida.
Texas Tech, Team 22-5, Rauch Spring 2016 Membro di Texas Tech, Team 22-5, Rauch Spring 2016
TTU-RAUCH-S16S22G5
3 Membri
1 Guida realizzata
1Commento della guida
GumOut Cleaner seems to be initially intended for Brakes and other auto parts. Is that the product you intend?
dan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 51
Tutti i Tempi: 40,158
