Salta al contenuto principale
How to Fix a Squeaky Door Hinge
Jake Herson
Jake Herson e 2 altri collaboratori
Ultimo aggiornamento il December 2, 2021
10 minuti
Facile
Introduzione
Vai al passo 1
Squeaky doors are a constant nuisance around most households. Use this guide to take apart a door hinge, oil it, and reassemble it. This easy repair should help quiet any squeaky door.
  1. How to Fix a Squeaky Door Hinge, How to Fix a Squeaky Door Hinge: passo 1, immagine 1 di 1
    • Insert the end of the flathead screwdriver into the crease between the top of the pin and the hinge.
  2. How to Fix a Squeaky Door Hinge: passo 2, immagine 1 di 1
    • Take the hammer and hit the handle end of the screwdriver until the pin can be pulled out. This may take a while depending on the door.
  3. How to Fix a Squeaky Door Hinge: passo 3, immagine 1 di 1
    • Place the pin in a bowl of mineral oil (or other household lubricant) and let it rest.
  4. How to Fix a Squeaky Door Hinge: passo 4, immagine 1 di 1
    • Use a brush to apply oil to the empty hinge.
  5. How to Fix a Squeaky Door Hinge: passo 5, immagine 1 di 1
    • Take the pin from the bowl and reinsert it into the door hinge, using a hammer if necessary.
    • Open and close the door a few times. This will help the oil to seep into the cracks of the hinge.
  6. How to Fix a Squeaky Door Hinge: passo 7, immagine 1 di 1
    • Use a towel to catch any drips of oil and to wipe off the hinge.
Conclusione
The door should now be quite silent when opening and closing. Thank you for reading.
Altre 3 persone hanno completato questa guida.
Jake Herson
Membro da: 03/30/16
219 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 42
Ultimi 30 Giorni: 264
Tutti i Tempi: 7,089
