How to Fix a Loose Connection on a Power Strip
Introduzione
Vai al passo 1A power strip is a useful and convenient device that allows you to plug multiple electronic devices into a single power outlet. However, over time, the contacts on a power strip may become loose or worn, which can result in a poor electrical connection and cause your devices to malfunction.
If you're experiencing this problem, one potential solution is to fix the loose contact by bending the contact clamp back into shape. In this guide, we'll walk you through the steps you can take to to fix a loose contact on your power strip using this method.
With a little bit of patience and the right tools, you can restore your power strip to optimal working condition in no time.
Cosa ti serve
Strumenti
Take out all the plugs on the power strip.
You’re all done!
You’re all done!
