Salta al contenuto principale
How to Fix a Leaky Gutter
Aya Mansour
Aya Mansour e un altro collaboratore
Ultimo aggiornamento il March 2, 2023
55 minuti - 2 ore
Moderato
Necessarie Immagini Migliori
Necessarie Più Immagini
Introduzione
Vai al passo 1
This guide discusses how to fix a leaky gutter will help beginners who need to fix a leaky gutter without having to hire a professional and can do it on their own, no experience required! I think this guide is needed since it can be extremely expensive to get a professional to help with a leaky gutter system. Also, sometimes professionals can be busy and possibly have you wait a week or so for them to come over and fix the problem. When gutters are leaking and one does not fix the problem, it could result in roof problems and wood rot.
  1. How to Fix a Leaky Gutter, How to Fix a Leaky Gutter: passo 1, immagine 1 di 3 How to Fix a Leaky Gutter, How to Fix a Leaky Gutter: passo 1, immagine 2 di 3 How to Fix a Leaky Gutter, How to Fix a Leaky Gutter: passo 1, immagine 3 di 3
    • Clean the area around the leak with a wire bush or garden trowel and a bucket, taking out the leaves and debris placing what you remove in the bucket and flushing the gutters with water using a hose to make sure you have a clean area, as well as rinsing and drying the area thoroughly.
    • Since this requires a ladder, it is better to have another adult nearby just to stay safe!
  2. How to Fix a Leaky Gutter: passo 2, immagine 1 di 1
    • Apply plastic roofing cement to any holes present in the gutters by working it into the hole or crack with a putty knife or trowel.
  3. How to Fix a Leaky Gutter: passo 3, immagine 1 di 1
    • Smooth out the cement by using the putty knife or trowel so that can smooth out any rough edges.
  4. How to Fix a Leaky Gutter: passo 4, immagine 1 di 1
    • Remove any screws or connecting hardware at the joint of any leaking or worn portion of the downspout and then disassemble any leaking or worn portion of the downspout joint.
  5. How to Fix a Leaky Gutter: passo 5, immagine 1 di 1
    • Clean any caulks from around the downspout joints using a stiff wire brush.
  6. How to Fix a Leaky Gutter: passo 6, immagine 1 di 1
    • Apply the silicone caulk to the joint area to seal leaks and reassemble the gutter system.
Conclusione
To reassemble the downsprout: screw back any screws or connecting hardware back into the downsprout.
Altre 3 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 58
Tutti i Tempi: 2,342
