Salta al contenuto principale
How to Fix a Hole In Wall
Darrian Johnson
Darrian Johnson e 4 altri collaboratori
Ultimo aggiornamento il October 8, 2024
1 ora
Moderato
Guida Studente in Evidenza
Introduzione
Vai al passo 1
Have you ever opened a door too hard and it hit the wall causing a small hole in the wall? This is a problem that so many people have, especially with children in the home. Most modern homes have walls made of a material called drywall. A hole in drywall is very easy to patch. It requires no prior skill or experience. This fix requires inexpensive tools and materials that you may find at a local hardware store or you may even already have some of these items at home. This is a guide on how to patch a small hole in the wall for beginners. This guide will include a complete step by step guide along with all tools and materials that are needed to complete this task.
  1. How to Fix a Hole In Wall, Dry wall: passo 1, immagine 1 di 3 How to Fix a Hole In Wall, Dry wall: passo 1, immagine 2 di 3 How to Fix a Hole In Wall, Dry wall: passo 1, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Use pliers (or tweezers if the hole is very small) to clean out hole by removing the drywall out of the hole.
  2. How to Fix a Hole In Wall: passo 2, immagine 1 di 1
    • Use scissors to cut drywall mesh.
    • To ensure that the entire hole is covered, cut a piece of mesh larger than the size of the hole.
  3. How to Fix a Hole In Wall: passo 3, immagine 1 di 2 How to Fix a Hole In Wall: passo 3, immagine 2 di 2
    • Use a damp sponge to apply moisture to make the mesh stick to the wall, covering the entire hole.
  4. How to Fix a Hole In Wall: passo 4, immagine 1 di 3 How to Fix a Hole In Wall: passo 4, immagine 2 di 3 How to Fix a Hole In Wall: passo 4, immagine 3 di 3
    • Use a drywall knife to apply the drywall compound over the mesh. Make sure to spread a generous amount over the entire mesh.
    • Let the compound dry for about 30 minutes.
    • You can speed up the drying process by placing a fan directly in front of the drying compound.
  5. How to Fix a Hole In Wall: passo 5, immagine 1 di 1
    • Once compound is dry, use sandpaper to smooth out the entire surface of the dried compound.
  6. How to Fix a Hole In Wall: passo 6, immagine 1 di 3 How to Fix a Hole In Wall: passo 6, immagine 2 di 3 How to Fix a Hole In Wall: passo 6, immagine 3 di 3
    • Paint over the surface with a paint brush.
    • Use paint that matches the rest of the wall for best results.
Conclusione
Altre 5 persone hanno completato questa guida.
1Commento della guida
Oi! como faço reboca que a parede está pintada branca?
dezinho anderson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 82
Tutti i Tempi: 7,255
