Salta al contenuto principale
How to Fix a Correcting Tape
Yi Luo
Yi Luo e 2 altri collaboratori
Ultimo aggiornamento il December 16, 2018
15 minuti
Facile
Introduzione
Vai al passo 1
This guide will show you how to repair a correcting tape within a few steps and make a full used of it.
Cosa ti serve
Strumenti
Mostra di più…
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. How to Fix a Correcting Tape, How to Fix a Correcting Tape: passo 1, immagine 1 di 2 How to Fix a Correcting Tape, How to Fix a Correcting Tape: passo 1, immagine 2 di 2
    • From the button, open the case of the correcting tape.
  2. How to Fix a Correcting Tape: passo 2, immagine 1 di 2 How to Fix a Correcting Tape: passo 2, immagine 2 di 2
    • Cut from the middle of the extra correcting tape and remove those used parts.
    • Cut off those used parts from the place near the small gear.
  3. How to Fix a Correcting Tape: passo 3, immagine 1 di 1
    • Cut a small piece of the scotch tape.
  4. How to Fix a Correcting Tape: passo 4, immagine 1 di 1
    • Connect the remaining correction tape to the small gear by using a small piece of scotch tape.
  5. How to Fix a Correcting Tape: passo 5, immagine 1 di 1
    • After the connection is made, wrap the used tape tightly around the gear.
    • Put all the parts back in place.
  6. How to Fix a Correcting Tape: passo 6, immagine 1 di 1
    • Close the case of the correcting tape and snap back to place.
  7. How to Fix a Correcting Tape: passo 7, immagine 1 di 1
    • You're done!
Conclusione
Altre 5 persone hanno completato questa guida.
Yi Luo
Membro da: 10/26/18
220 Reputazione
1 Guida realizzata
UC Davis, Team S2-G5, Bender Fall 2018 Membro di UC Davis, Team S2-G5, Bender Fall 2018
UCD-BENDER-F18S2G5
2 Membri
1 Guida realizzata
3Commenti sulla guida
It probably cost me more time to put it together (first time) than it would to buy a new one. Doesn’t matter, fixed a problem! A sense of accomplishment and pride. %#*@, I love it so much.
Thanks for the guide.
The Swanson Disciple - Replica
This stuff is absolute junk! Wish I could find it packaged the old way, like Avery correction tape used to be, in little cardboard boxes. Hate all that plastic and these things always break for me!
Laker Girl - Replica
Well thank you for helping us and that was quite a shot thank you and god bless you and be safe during the virus!
Peata Faalaa - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 30
Ultimi 30 Giorni: 140
Tutti i Tempi: 34,762
