Salta al contenuto principale
How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer
Xie Zheng
Xie Zheng e un altro collaboratore
Ultimo aggiornamento il 10 feb 2024
20 - 40 minuti
Moderato
Introduzione
Vai al passo 1
This repair aims to resolve a potential connection issue that could occur any time after excessive use of gaming desktops. PC outlets usually charge an unfair amount of money to perform simple fixes, so this guide should help you save your wallet. Gaming monitors sometimes may not respond after pressing the start-up button and this may be simply caused by a connection issue between the internal graphics card and the monitor. I will perform how to properly check and resolve this issue so that the monitor will have a correct display using a rubber or eraser. Use caution when doing this guide that you don't get dust or debris in your PC when applying this method or use an eraser that doesn't flake.
To ensure your success on the repair, please give yourself a clean and clear area for placing additional PC parts/screws.
Make sure to power off your PC completely and disconnect from any external power source prior to beginning the process.
Cosa ti serve
Strumenti
  1. How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer, How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: passo 1, immagine 1 di 3 How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer, How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: passo 1, immagine 2 di 3 How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer, How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: passo 1, immagine 3 di 3
    • Unplug your device from all power and turn off the device as well.
    • Always remember to turn off the power for safety measures. Additionally, disconnect the main power cable from your PC (as indicated in the images) and you are safe to go.
  2. How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: passo 2, immagine 1 di 3 How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: passo 2, immagine 2 di 3 How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: passo 2, immagine 3 di 3
    • Using a screwdriver or potentially just your hands, remove the panel from the PC case. You might have to remove screws but cases vary.
    • If your case happens to have screws on the back panel, simply remove them, but do remember to correctly distribute all the screws in a cleared area so that you don’t lose any of them while performing additional steps later.
  3. How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: passo 3, immagine 1 di 3 How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: passo 3, immagine 2 di 3 How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: passo 3, immagine 3 di 3
    • Once the back panel of your PC case is opened, disconnect the graphics card from both the monitor and the motherboard.
    • Take a picture of how the wires are connected so that you don’t mess up when you try to put it back later.
    • Be gentle and careful working with connection wires. Connection wires are easy to find but are usually loose and vulnerable.
  4. How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: passo 4, immagine 1 di 1
    • Disconnect and separate the graphics card from the motherboard and the PC case.
    • Use a screwdriver to remove the screw(s) (1.2mm factory issued) on the side panel to separate your graphics card from both your motherboard and your PC. There's one more step before you can completely release your graphics card from your case.
  5. How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: passo 5, immagine 1 di 3 How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: passo 5, immagine 2 di 3 How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: passo 5, immagine 3 di 3
    • Notice the little black clip on the motherboard next to the graphics card. That is the release key.
    • If the clip is a bit too deep to reach, find a stick and press it down so that you can pull up your graphics card with no stress.
    • Pull out the graphics card and lay it down on a flat surface.
  6. How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: passo 6, immagine 1 di 3 How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: passo 6, immagine 2 di 3 How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: passo 6, immagine 3 di 3
    • The gold spike edge is usually identified as the connecting finger of many electronic parts.
    • Softly clean the connecting finger with a rubber. Remember to rub both sides of the connecting finger.
  7. How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: passo 7, immagine 1 di 3 How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: passo 7, immagine 2 di 3 How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: passo 7, immagine 3 di 3
    • Take out the RAM sticks. These RAM sticks are fixed and attached to the RAM slots on the motherboard. They can be easily damaged if you attempt to pull them out straight.
    • Loosen the clips on both sides of the RAM slot first and then unplug the RAM. It should be fairly easy once you unclip the slot.
  8. How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: passo 8, immagine 1 di 2 How to Fix a Connection Problem With A Gaming Monitor and Desktop Computer: passo 8, immagine 2 di 2
    • Use the rubber to clean the connecting finger of the RAM.
Conclusione
Preparati per le riparazioni future
Acquista tutti
Xie Zheng
Membro da: 02/02/22
181 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 34
Tutti i Tempi: 884
