Salta al contenuto principale
How to Fix Snagged Jeans
Samantha Parison
Samantha Parison e 16 altri collaboratori
Ultimo aggiornamento il 4 gen 2023
25 - 35 minuti
Facile
Necessarie Più Immagini
Tagliatore di Passi
Introduzione
Vai al passo 1
Repair snagged jeans with simple skills, such as threading a needle or tying a knot. Repairing the snagged denim will prevent further tearing, and will make the denim more visually appealing.
Cosa ti serve
Strumenti
Mostra di più…
  1. How to Fix Snagged Jeans, How to Fix Snagged Jeans: passo 1, immagine 1 di 3 How to Fix Snagged Jeans, How to Fix Snagged Jeans: passo 1, immagine 2 di 3 How to Fix Snagged Jeans, How to Fix Snagged Jeans: passo 1, immagine 3 di 3
    • Identify the snag that you would like to correct.
    • Insert the sharp end of your ballpoint needle through the centre of the snag.
    • Carefully turn the jeans inside out, while maintaining the placement of the ballpoint needle.
  2. How to Fix Snagged Jeans: passo 2, immagine 1 di 2 How to Fix Snagged Jeans: passo 2, immagine 2 di 2
    • Allow the ballpoint needle to stand vertically. This will happen naturally.
    • Take your No. 18 tapestry needle and gently maneuver all of the loose strings from the snagged denim to the inside of the jeans. You will position your needle to pull the loose strings upward.
    • Make sure there are no loose strings left outside of the jeans.
  3. How to Fix Snagged Jeans: passo 3, immagine 1 di 2 How to Fix Snagged Jeans: passo 3, immagine 2 di 2
    • String the No. 18 tapestry needle with your thread.
    • Tie both ends of the thread to form a small, tight knot.
  4. How to Fix Snagged Jeans: passo 4, immagine 1 di 3 How to Fix Snagged Jeans: passo 4, immagine 2 di 3 How to Fix Snagged Jeans: passo 4, immagine 3 di 3
    • Make another knot, this time pull thread slowly and tightly around the snag.
    • Get the knot as close as possible to the surface of the denim jean.
    • Pull the knot as tight as possible.
  5. How to Fix Snagged Jeans: passo 5, immagine 1 di 1
    • Use the scissors to trim the excess thread on both sides.
  6. How to Fix Snagged Jeans: passo 6, immagine 1 di 1
    • Once you've removed the excess thread, take a small amount of fabric adhesive, and rub it against the knot you made to confident the snagged denim. The adhesive will secure the loose strings inside the denim.
    • Apply the adhesive so that the knot is stuck to the surface of the denim.
    • Allow the adhesive at least 20 minutes to dry.
  7. How to Fix Snagged Jeans: passo 7, immagine 1 di 2 How to Fix Snagged Jeans: passo 7, immagine 2 di 2
    • Turn the jeans right side out. The snag is no more!
Linea Traguardo
Altre 3 persone hanno completato questa guida.
5Commenti sulla guida
wtf?! make your nails first!
bettyanisko - Replica
beautiful nails
John - Replica
Exactly how do you determine which thread to pull on the reverse side of jeans??!! It was not obvious, and this ‘how to’ didn’t explain that essential part. Struggled for 15 min, then went on to another youtube how-to that worked easily (https://www.youtube.com/watch?v=--tHHF_M... ). With this other tutorial, I fixed two pairs in under 10 min.
Sherry Quinn - Replica
I did have to try to find the strings (that were snagged) to pull through but with a little patience it worked beautifully! Thanks for the tutorial! I was proud of myself for finally using my little sowing kit! And people are jerks with the comments!
Karen Funk - Replica
Thank you! This was helpful! I thought about fabric adhesive to secure the loose ends on the inside of the jeans, but so glad to know that you recommend it! Great photos!
Cheri - 5/31/2021
Cheri Johnson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 32
Ultimi 30 Giorni: 109
Tutti i Tempi: 50,885
