How to Fix Snagged Jeans
Introduzione
Vai al passo 1Repair snagged jeans with simple skills, such as threading a needle or tying a knot. Repairing the snagged denim will prevent further tearing, and will make the denim more visually appealing.
Cosa ti serve
Strumenti
Mostra di più…
Identify the snag that you would like to correct.
Insert the sharp end of your ballpoint needle through the centre of the snag.
Carefully turn the jeans inside out, while maintaining the placement of the ballpoint needle.
Altre 3 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti5Commenti sulla guida
wtf?! make your nails first!
Exactly how do you determine which thread to pull on the reverse side of jeans??!! It was not obvious, and this ‘how to’ didn’t explain that essential part. Struggled for 15 min, then went on to another youtube how-to that worked easily (https://www.youtube.com/watch?v=--tHHF_M... ). With this other tutorial, I fixed two pairs in under 10 min.
I did have to try to find the strings (that were snagged) to pull through but with a little patience it worked beautifully! Thanks for the tutorial! I was proud of myself for finally using my little sowing kit! And people are jerks with the comments!
Thank you! This was helpful! I thought about fabric adhesive to secure the loose ends on the inside of the jeans, but so glad to know that you recommend it! Great photos!
Cheri - 5/31/2021
