Salta al contenuto principale
How to Fix Cracked Door Jamb
Anisha Karaumbiah
Anisha Karaumbiah e 2 altri collaboratori
Ultimo aggiornamento il June 2, 2022
40 minuti
Moderato
Introduzione
Vai al passo 1
A cracked door frame can often deteriorate in time but can be salvaged when fixed with a repair kit. This guide will help homeowners repair cracks in the door frame on their own and at a very low cost, without having to replace the entire door frame.
  1. How to Fix Cracked Door Jamb, How to Fix Cracked Door Jamb: passo 1, immagine 1 di 1
    • Cracked door jamb/frame caused by excessive force on door.
  2. How to Fix Cracked Door Jamb: passo 2, immagine 1 di 1
    • Apply wood filler into the cracks of the door frame.
  3. How to Fix Cracked Door Jamb: passo 3, immagine 1 di 2 How to Fix Cracked Door Jamb: passo 3, immagine 2 di 2
    • Attach the clamp onto the cracked door frame.
    • Use a clamp with rubber edges for a sturdier grip and also to prevent damaging the door frame.
  4. How to Fix Cracked Door Jamb: passo 4, immagine 1 di 2 How to Fix Cracked Door Jamb: passo 4, immagine 2 di 2
    • Drill a pilot hole into the door frame.
    • Screw a 4-inch screw into the frame through the pilot hole.
  5. How to Fix Cracked Door Jamb: passo 5, immagine 1 di 1
    • Wait for the wood filler to dry.
    • Once dried, scrape off the excess filler with a scraper.
  6. How to Fix Cracked Door Jamb: passo 6, immagine 1 di 1
    • Sand the filled up cracks to get a smooth surface.
  7. How to Fix Cracked Door Jamb: passo 7, immagine 1 di 1
    • Paint and do not touch until dry.
  8. How to Fix Cracked Door Jamb: passo 8, immagine 1 di 2 How to Fix Cracked Door Jamb: passo 8, immagine 2 di 2
    • Repaired door frame/ door jamb.
Linea Traguardo
Altre 4 persone hanno completato questa guida.
UC Davis, Team S1-G1, Andersen Winter 2018 Membro di UC Davis, Team S1-G1, Andersen Winter 2018
UCD-ANDERSEN-W18S1G1
1 Membro
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 34
Ultimi 30 Giorni: 125
Tutti i Tempi: 44,797
