Salta al contenuto principale
How to Fix Anything
How to Fix Anything
Davide
Davide e 2 altri collaboratori
Ultimo aggiornamento il January 15, 2025
30 minuti
Molto facile
Necessarie Più Immagini
Guida fornita dalla comunità
Introduzione
Vai al passo 1
These are the preliminary steps that are often useful when you think about repairing something.
  1. How to Fix Anything, Define the Problem: passo 1, immagine 1 di 1
    • Try to describe what your device is doing and what instead you expect it to do.
    • If it is not obvious, check if the behaviour is actually a problem or not.
    • Pro tip: even if this is the intended behaviour, you are entitled to modify it, if you like. Just it's not "fixing" anymore: that's hacking!
    • Did you forget to put the plug in the socket? Did you check the battery? Is the light bulb burn out?
    • In Europe, everything has two years of warranty by law. Do not give up your rights!
    • There is a very good chance that you will find something useful with a little search online.
  2. How to Fix Anything, Talk to your Community: passo 6, immagine 1 di 1
    • Speak with friends, family or colleagues. Even if they don't know anything, speaking helps a lot the reasoning.
    • Speak to a rubber duck
  3. How to Fix Anything, Mind the safety.: passo 7, immagine 1 di 1
    • Take a minute to think if there is anything that could be a safety hazard.
    • Check the user manual and the package, if available, and the device itself for any danger label.
Conclusione
You are now ready to repair your stuff!
Altre 17 persone hanno completato questa guida.
Davide
Membro da: 07/15/16
710 Reputazione
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 31
Ultimi 30 Giorni: 161
Tutti i Tempi: 3,408
