How to Fill a Crack in a Glass Container
Introduzione
Vai al passo 1This guide gives step by step instructions on how to repair any cracked glass vase or jar. The main tool being used in this guide is two part epoxy to cure the crack. By following this guide you will be able to get more out of your glass and reduce the amount of waste you produce. Be sure to be careful while dealing with broken glass and if needed wear protective equpiment during the repair. Before begining the repair be sure to be in a safe enviornment where glass can be handled.
Cosa ti serve
Strumenti
Mostra di più…
Clean the jar or vase with dish soap to remove all dust, fingerprints and dirt.
Dry the glass using a paper towel, and allow it time to completely dry.
Thanks for following our guide! We hope it was simple and helped you to reduce your amount of waste!!
Altre 2 persone hanno completato questa guida.
