Salta al contenuto principale
How to Extend A Necklace Chain
MaryJane M.
MaryJane M. e 4 altri collaboratori
Ultimo aggiornamento il May 7, 2024
6 minuti
Molto facile
Introduzione
Vai al passo 1
Have you ever purchased a piece of jewelry, like a necklace for example, and realized that it was too small once you tried to put it on? This guide will give you the step-by-step process to extend your necklace using jewelry chain and enjoy wearing it comfortably.
Cosa ti serve
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. How to Extend A Necklace Chain, Necklace Chain: passo 1, immagine 1 di 1
    • Use nail clippers to cut the links off of your extension chain until it is your desired length.
  2. How to Extend A Necklace Chain: passo 2, immagine 1 di 1
    • Remove the links you just cut from the end of the extension chain so you have a chain of your desired length.
  3. How to Extend A Necklace Chain: passo 3, immagine 1 di 2 How to Extend A Necklace Chain: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Use the pliers/tweezers to grip the ends of the last link you removed and pull it open to widen the gap.
  4. How to Extend A Necklace Chain: passo 4, immagine 1 di 1
    • Thread the link you just opened wider through your original necklace chain.
  5. How to Extend A Necklace Chain: passo 5, immagine 1 di 1
    • With the link attached to the original necklace chain, attach the extension chain to the same link.
  6. How to Extend A Necklace Chain: passo 6, immagine 1 di 1
    • Use the pliers/tweezers to pinch the link shut around both chains.
  7. How to Extend A Necklace Chain: passo 7, immagine 1 di 1
    • Using the original latch, clip the latch to the extension chain. Your final product should look like a seamless chain!
Conclusione
This necklace is now ready to wear, and the chain can be extended with this method many times!
MaryJane M.
Membro da: 02/02/23
145 Reputazione
1 Guida realizzata
UC Davis, Team 4-5, Andersen Winter 2023 Membro di UC Davis, Team 4-5, Andersen Winter 2023
UCD-ANDERSEN-W23S4G5
3 Membri
1 Guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 21
Tutti i Tempi: 472
