Salta al contenuto principale
How to Change Broken Buttons on your Lexus Key Fob
Michael Tan
Michael Tan e 4 altri collaboratori
Ultimo aggiornamento il August 24, 2023
10 - 15 minuti
Facile
Introduzione
Vai al passo 1
Are the buttons on your Lexus key fob not responding anymore? Use this guide to learn how to open the key fob and swap out the buttons. The only tool you will need to complete this repair is your key fob!
  1. How to Change Broken Buttons on your Lexus Key Fob, Broken Buttons: passo 1, immagine 1 di 2 How to Change Broken Buttons on your Lexus Key Fob, Broken Buttons: passo 1, immagine 2 di 2
    • Place the key fob with the removable metal key facing towards you.
  2. How to Change Broken Buttons on your Lexus Key Fob: passo 2, immagine 1 di 3 How to Change Broken Buttons on your Lexus Key Fob: passo 2, immagine 2 di 3 How to Change Broken Buttons on your Lexus Key Fob: passo 2, immagine 3 di 3
    • With the button side facing you, pull the metal latch down towards you to pull out the key.
  3. How to Change Broken Buttons on your Lexus Key Fob: passo 3, immagine 1 di 3 How to Change Broken Buttons on your Lexus Key Fob: passo 3, immagine 2 di 3 How to Change Broken Buttons on your Lexus Key Fob: passo 3, immagine 3 di 3
    • With the exposed corner facing you, place the metal key into the slot.
    • Turn the key sideways to open the key fob.
    • You may feel like you're breaking the key fob, but be firm while twisting.
  4. How to Change Broken Buttons on your Lexus Key Fob: passo 4, immagine 1 di 2 How to Change Broken Buttons on your Lexus Key Fob: passo 4, immagine 2 di 2
    • Remove the motherboard and battery to access the buttons.
  5. How to Change Broken Buttons on your Lexus Key Fob: passo 5, immagine 1 di 3 How to Change Broken Buttons on your Lexus Key Fob: passo 5, immagine 2 di 3 How to Change Broken Buttons on your Lexus Key Fob: passo 5, immagine 3 di 3
    • Rotate the front plate, the broken buttons should fall out with ease.
    • Replace the broken buttons as necessary.
Conclusione
To reassemble your device, follow these instructions in reverse order. Apply firm pressure when snapping the front and back covers together.
Altre 7 persone hanno completato questa guida.
Michael Tan
Membro da: 01/08/15
590 Reputazione
3 Guide realizzate
Cal Poly, Team 30-3, Green Spring 2015 Membro di Cal Poly, Team 30-3, Green Spring 2015
CPSU-GREEN-S15S30G3
4 Membri
10 Guide realizzate
Un commento
useless guide
Davide - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 45
Tutti i Tempi: 6,712
