Salta al contenuto principale
How to Bypass the Hydotech 89-series Control Valve
N. T. Crotser
N. T. Crotser e un altro collaboratore
Ultimo aggiornamento il 5 nov 2024
30 secondi
Molto facile
Guida fornita dalla comunità
Introduzione
Vai al passo 1
Bypassing the Hydrotech 89-series control valve is essential for addressing leaks or performing maintenance on the system. This guide will walk you through the process of using the integrated bypass feature to safely bypass the control valve.
Cosa ti serve
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. How to Bypass the Hydotech 89-series Control Valve, Locating the Integrated Bypass: passo 1, immagine 1 di 1
    • Locate the red bypass knobs located between the control valve body and your home's plumbing.
    • Over time, these knobs may become difficult to move by hand, an 8mm Allen wrench (included with the valve) will help make this procedure easier.
    • Turn each knob to the inside so the knobs are in line with each other.
    • Use caution when pulling the Allen wrench out, the knobs may become unseated from the bypass assembly. If this happens, simply remove the knob from the Allen wrench and push down to reseat the knob in it's current position.
Conclusione
To put the control valve back into service, follow Step 2 in reverse order.
Documenti Allegati
N. T. Crotser
Membro da: 06/13/22
928 Reputazione
6 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 18
