Introduzione
Use this guide to apply liquid metal in your PlayStation 5. You can also use this guide to re-spread existing liquid metal.
Your PS5 has an Accelerated Processing Unit (APU), which uses liquid metal TIM (thermal interface material) instead of traditional thermal paste to transfer heat. Over time, the liquid metal can oxidize or become unevenly spread on the APU and heatsink, especially if the PS5 stood upright for long periods of time. If the liquid metal has oxidized, it'll look dried-out or cracked and will need to be cleaned and replaced. If it's just unevenly covered, you can re-spread it evenly across the surfaces of the APU and heatsink.
Your liquid metal might need to be replaced if your PS5 is overheating, throttling, or having overall poor performance. These signs could also mean a faulty or dirty fan. To remove your fan for cleaning, follow this guide.
Cosa ti serve
If your PlayStation 5 is in its vertical orientation, flip it upside down so the stand is facing up.
Use a coin or a flathead screwdriver to remove the 26.5 mm-long stand screw.
If your PlayStation 5 is in its horizontal orientation, rest it on its face with the charging port facing up.
Lift the stand straight up to remove it.
Flip the device over so that the USB and ethernet ports are on the left side from your perspective.
Lift up the corner of the faceplate to unclip it from the case.
Insert the flat end of a spudger underneath the grille and into the gap above the fan.
Lift up with the spudger to pry the grille away from the case.
Attrezzo utilizzato in questo passaggio:Magnetic Project Mat$19.95
Use a TR8 Torx security driver to remove the four screws securing the fan shroud to the case:
Two 23.3 mm-long screws
One 11.4 mm-long screw
One 31 mm-long screw
Insert the flat end of a spudger beneath the black wire cover and into the gap above the fan wires.
Use the spudger to peel up the wire cover until you can grip it with your fingers.
Use your fingers to grip the edges of the fan cable connector, and pull up to disconnect it from the motherboard.
Use a Phillips screwdriver to remove the 17 mm-long SSD cover screw.
Use your fingers to grip the edges of the optical drive cable connector, and pull up to disconnect it from the motherboard.
Use a T8 Torx driver to remove the eleven screws securing the case:
Six 18.6 mm-long screws
Two 43.2 mm-long screws
One 7.3 mm-long screw
Use the flat end of a spudger to press down on the optical drive connector's metal locking tab.
With the metal tab depressed, use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the cable from the optical drive.
Lift the optical drive away from the device to remove it.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
With the metal tab depressed, use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the cable from the motherboard.
Use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the power and eject button ribbon cable.
Use a pair of tweezers to pull the blue pull tab directly away from the connector to disconnect the LED ribbon cable.
Use a pair of tweezers to grip the white Wi-Fi antenna wire at its metal base, as close to the connector as possible.
Lift the wire's connector straight up to disconnect it from the motherboard.
Repeat for the black Wi-Fi antenna wire.
Use a pair of tweezers to peel back the white sticker holding the antenna wires to the top shield plate.
Remove the antenna wires from underneath the sticker.
Press the white sticker back down onto the top shield plate so it can be reused.
Use a T8 Torx driver to remove the forty-two screws securing the top shield plate:
Forty-one 7.3 mm-long screws
One 43.2 mm-long screw
Lift the top shield plate off of the motherboard to remove it.
Use your finger to depress the metal locking tab on the USB board cable's board connector.
With the metal tab depressed, place the flat end of a spudger against the insulating foam pad on the ribbon cable and pull it directly away from the connector to disconnect it.
Use a Phillips screwdriver to remove the 11 mm‑long SSD screw.
Use a Phillips screwdriver to remove the two 11.8 mm‑long APU bracket screws.
Use a TR8 Torx security screwdriver to remove the two remaining 7.3 mm‑long main board screws.
Gently lift the edge of the motherboard with the large cutout to partially separate it from the bottom shield plate.
With the board lifted, insert the flat end of a spudger between the board and the bottom shield plate and gently twist to separate them. Work your way around the perimeter of the board.
Insert the flat end of a spudger between the board and the lower shield plate, by the two parallel solder joints near the corner with the power button.
Twist the spudger to lift the two prongs under the board out of their socket.
Remove the main board, flip it over, and lay it on a clean cloth, so the APU is facing up.
Make sure all cables that connect to the board are out of the way so they don't get trapped underneath.
Carefully flip the board over so the APU is on the bottom, making sure no liquid metal spills.
Keep the board level and lower it into place.
Attrezzo utilizzato in questo passaggio:Dispensing Syringe Kit 9 pieces$8.99
If you have a disposable syringe, you can use it to suck up any large pools of liquid metal. Don't use the syringe containing your new liquid metal.
Starting with the heatsink: apply a few drops of highly-concentrated (greater than 90%) isopropyl alcohol to a cotton swab and carefully clean up all of the liquid metal from the heatsink surface.
Use the same cleaning process to thoroughly clean up all of the liquid metal residue.
Let the heatsink dry completely.
Just as you did for the heatsink, clean and remove all of the old liquid metal and its residue from the APU.
This is a good point to replace any thermal pads on the bottom of the main board, if necessary. The pads might be stuck to both the bottom shield plate and the main board.
Apply a small drop of liquid metal to the heatsink (not the APU)—about the size of a matchstick head.
Use the spreader that came with your liquid metal or a new cotton swab to lightly push down on and evenly spread the liquid metal across the entire surface.
If there's excess liquid metal anywhere, use the syringe to suck it back up.
To reassemble your device, follow these instructions in reverse order, starting with this step.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our PlayStation 5 Answers community for help.
