Salta al contenuto principale
How To Use And Maintain Your Hand Mixer
    • Use plastic, glass, or metal bowls for the best mixing results.
    • Avoid Teflon bowls because the metal beaters can damage the coating.
    • Use two mixers if necessary for large batches to prevent excess strain on one device.
    • Keep the whisk attachments from colliding by positioning them carefully.
    • Attach the whisk beaters and place them in the mix for small batches like single eggs or pudding base.
    • Move the mixer in the same direction as the spinning beaters to pull ingredients inward.
    • Reverse direction if you want to add more air to the mixture and increase volume.
    • Grip the bowl near the side to create a fountain effect and speed up the whisking process.
    • Immerse the mixer completely when whisking tall liquids like instant coffee with water.
    • Move the mixer up and down gently to incorporate air and create foam.
    • Cook the potatoes, add butter and cream, and use moderate speed to avoid gummy texture.
    • Keep speed in a medium range so gluten does not form and potatoes remain fluffy.
    • Fit the whisks and pass cooked foods through a mesh strainer without applying too much pressure.
    • Allow the rotating whisks to separate the pulp and produce a smooth sauce or puree.
    • Use dough hooks for all kinds of dough, with each hook matched to its correct slot.
    • Combine dry ingredients by hand first to avoid pulling flour or sugar into the motor.
    • Increase speed if the dough is stiff, then listen for unusual grinding or straining sounds.
    • Unplug the mixer before cleaning or repairing to prevent electric hazards.
    • Clean beaters in a dishwasher or sink and wipe the device housing with a damp cloth.
    • Avoid motor overload by partially mixing dough or batter by hand at the start.
    • Check the manufacturer’s instructions for routine upkeep and warranty details.
Conclusione
Using the correct bowl, speed settings, and accessory for each task keeps your mixer running smoothly for years. Unplug it before performing any maintenance to stay safe and protect your warranty. With mindful preparation, proper cleaning, and gentle care, the simple hand mixer can be a reliable part of any kitchen for a long time.
Ula Gantar
Membro da: 01/08/25
16.474 Reputazione
48 Guide realizzate
ZEOS Slovenia Membro di ZEOS Slovenia
Local Repair Groups
2 Membri
56 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 5
Tutti i Tempi: 80
