Salta al contenuto principale
How To Remove Rust From Old Tools
Geoff Wacker
Geoff Wacker e 2 altri collaboratori
Ultimo aggiornamento il 31 lug 2024
15 minuti
Facile
Introduzione
Vai al passo 1
Do you have some rusty old tools laying around the house? Use this guide to remove that pesky rust and return your tools to good working condition.
Cosa ti serve
Strumenti
Mostra di più…
  1. How To Remove Rust From Old Tools, How To Remove Rust From Old Tools: passo 1, immagine 1 di 2 How To Remove Rust From Old Tools, How To Remove Rust From Old Tools: passo 1, immagine 2 di 2
    • Removing rust generally isn't dangerous, but it's pretty messy.
    • Prepare your workspace by laying out an old towel or shop rag that you won't mind getting dirty.
    • Consider also wearing protective gloves.
    • Place your tool on the towels.
  2. How To Remove Rust From Old Tools: passo 2, immagine 1 di 2 How To Remove Rust From Old Tools: passo 2, immagine 2 di 2
    • Spray the rusty areas of the tool with a generous amount of WD-40.
  3. How To Remove Rust From Old Tools: passo 3, immagine 1 di 3 How To Remove Rust From Old Tools: passo 3, immagine 2 di 3 How To Remove Rust From Old Tools: passo 3, immagine 3 di 3
    • Use a scouring pad to thoroughly scrub the tool.
    • It shouldn't take a lot of force—the WD-40 and scouring pad will do most of the work.
  4. How To Remove Rust From Old Tools: passo 4, immagine 1 di 3 How To Remove Rust From Old Tools: passo 4, immagine 2 di 3 How To Remove Rust From Old Tools: passo 4, immagine 3 di 3
    • Use a paper towel to wipe away the excess grime and WD-40.
  5. How To Remove Rust From Old Tools: passo 5, immagine 1 di 1
    • Continue scouring the tool, adding more WD-40 as needed, until the surface is free of rust.
    • When you finish, your tool may not look brand new—but the surface should now be rust-free and ready for years of continued use.
    you need to use a zoom in picture in step 4 for step 5!
    stephen harrison - Replica
Conclusione
Altre 11 persone hanno completato questa guida.
Geoff Wacker
Membro da: 09/30/13
91.330 Reputazione
89 Guide realizzate
2Commenti sulla guida
Apple cider vinegar removes rust well. Try it.
Michael Jucker - Replica
Thank you I have tried vinagar ,rust buster and other sprays and only the WD 40 worked best
Ronald Tyler - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 26
Ultimi 30 Giorni: 123
Tutti i Tempi: 6,385
