Salta al contenuto principale
Honeywell HY-204 Rotation Button Replacement
Nolan Ernotte
Nolan Ernotte e 4 altri collaboratori
Ultimo aggiornamento il September 3, 2019
15 - 20 minuti
Difficile
Introduzione
Vai al passo 1
This guide shows how to replace the rotation button that controls the oscillation of your fan. Replacing the rotation button requires soldering, so it may be a little tricky for those of you who are inexperienced with soldering.
Cosa ti serve
Strumenti
Mostra di più…
  1. Honeywell HY-204 Rotation Button Replacement, Case: passo 1, immagine 1 di 2 Honeywell HY-204 Rotation Button Replacement, Case: passo 1, immagine 2 di 2
    • Before you begin, be sure to unplug the fan.
    • Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
  2. Honeywell HY-204 Rotation Button Replacement: passo 2, immagine 1 di 2 Honeywell HY-204 Rotation Button Replacement: passo 2, immagine 2 di 2
    • Pull the front and back parts of the case away from each other until the back is free from the front. This may require a large amount of force.
  3. Honeywell HY-204 Rotation Button Replacement, Control Panel: passo 3, immagine 1 di 2 Honeywell HY-204 Rotation Button Replacement, Control Panel: passo 3, immagine 2 di 2
    • Remove the two 3mm screws found just below the top of the device using the Phillips #0 Screwdriver.
  4. Honeywell HY-204 Rotation Button Replacement: passo 4, immagine 1 di 1
    • Pry off the control panel by forcefully lifting the tab located inside the front of the fan with the plastic opening tool.
  5. Honeywell HY-204 Rotation Button Replacement, Rotation Button: passo 5, immagine 1 di 2 Honeywell HY-204 Rotation Button Replacement, Rotation Button: passo 5, immagine 2 di 2
    • Remove the two 10mm Phillips #0 screws that are located next to the rotation button.
  6. Honeywell HY-204 Rotation Button Replacement: passo 6, immagine 1 di 1
    • Peel back the heat shrink tubing on both wires connecting to the button.
  7. Honeywell HY-204 Rotation Button Replacement: passo 7, immagine 1 di 1
    • Caution The soldering iron is very hot, be careful to avoid burns.
    • Desolder the two wires connected to the button and remove the button.
Conclusione
Cal Poly, Team 10-40, Amido Fall 2014 Membro di Cal Poly, Team 10-40, Amido Fall 2014
CPSU-AMIDO-F14S10G40
3 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 987
