Salta al contenuto principale
Homedics UHE-CMP15 Water Replacement
Dylan
Dylan e 2 altri collaboratori
Ultimo aggiornamento il January 2, 2024
1 minuto
Molto facile
Introduzione
Vai al passo 1
If the water in your device's container smells bad, follow this guide to replace the water inside the container with clean and fresh water. For this guide you will need some sort of towel or cleaning device to clean the container.
Cosa ti serve
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Homedics UHE-CMP15 Water Replacement, Water: passo 1, immagine 1 di 1
    • Unscrew the container from the lid.
    • Turn the cap counterclockwise and gently remove the lid from the container.
  2. Homedics UHE-CMP15 Water Replacement: passo 2, immagine 1 di 1
    • Remove the water that is already in the container and dump the old water into safe water disposal area.
    • Dump the old water outside or down the sink.
  3. Homedics UHE-CMP15 Water Replacement: passo 3, immagine 1 di 1
    • Clean out the container.
    • Use a towel, some soap, and water to clean out the container.
    • You can also use a mix of 50/50 white vinegar and water to clean.
    • Take the damp towel and move it along all off the container and then rinse it out with water.
  4. Homedics UHE-CMP15 Water Replacement: passo 4, immagine 1 di 1
    • Fill the container with fresh water.
    • Take some room temperature water from the sink and pour it into the clean container.
Conclusione
Dylan
Membro da: 10/30/23
337 Reputazione
3 Guide realizzate
UMass Dartmouth, Team 3-6, Konn Fall 2023 Membro di UMass Dartmouth, Team 3-6, Konn Fall 2023
UMASSD-KONN-F23S3G6
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 158
