Salta al contenuto principale
Homedics UHE-CMP15 Charging Cable Cleaning
Kade Betterton
Kade Betterton e 3 altri collaboratori
Ultimo aggiornamento il January 2, 2024
2 minuti
Molto facile
Introduzione
Vai al passo 1
If the device is not charging, follow this guide to cleaning or replacing the charging cable. You will need a spudger and a spare type-c charging cable on hand.
Cosa ti serve
Ricambi
Strumenti
  • Spudger
    Spudger
Mostra di più…
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Homedics UHE-CMP15 Charging Cable Cleaning, Homedics UHE-CMP15 Charging Cable Cleaning: passo 1, immagine 1 di 2 Homedics UHE-CMP15 Charging Cable Cleaning, Homedics UHE-CMP15 Charging Cable Cleaning: passo 1, immagine 2 di 2
    • Check the USB port/both ends of the charging cable for dust or grime buildup.
  2. Homedics UHE-CMP15 Charging Cable Cleaning: passo 2, immagine 1 di 2 Homedics UHE-CMP15 Charging Cable Cleaning: passo 2, immagine 2 di 2
    • Clear out any buildup carefully with a plastic tool, never metal.
    • Gently rub the plastic tool of choice along the charging port and remove and dust that may have built up over time.
    • Try the charger again, you should see a red LED indicator if the device is charging.
  3. Homedics UHE-CMP15 Charging Cable Cleaning: passo 3, immagine 1 di 1
    • A red light should appear above the charging port when plugged in, if it does not then the charging cable should be replaced.
    • Purchase a replacement type-c charger or use another charger you already own to test again.
    • If this does not resolve the issue then the battery may be dead, or there is some other issue.
Conclusione
If this guide does not solve your charging problem, check out the battery replacement guide instead.
UMass Dartmouth, Team 3-6, Konn Fall 2023 Membro di UMass Dartmouth, Team 3-6, Konn Fall 2023
UMASSD-KONN-F23S3G6
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 124
