Salta al contenuto principale
Handheld Toilet Bidet Sprayer Replacement
Almuhannad Althurwi
Almuhannad Althurwi e 2 altri collaboratori
Ultimo aggiornamento il July 14, 2021
15 - 20 minuti
Facile
Introduzione
Vai al passo 1
The handheld toilet bidet sprayer is a simple but effective cleaning product. It is most common in the Middle East. It is important to know how to replace or fix one of them. People can replace or fix the handheld toilet bidet Sprayer when there is water leaking from the pipes. This is the most common reason to fix the handheld toilet bidet sprayer. If you need to replace a damaged or nonworking handheld toilet bidet sprayer, this guide will offer step by step instructions with visuals to help you.
  1. Handheld Toilet Bidet Sprayer Replacement, Handheld Toilet Bidet Sprayer: passo 1, immagine 1 di 1
    • Turn off the toilet water valve by turning the knob clockwise.
  2. Handheld Toilet Bidet Sprayer Replacement: passo 2, immagine 1 di 1
    • Flush the toilet until no water is left in the tank.
  3. Handheld Toilet Bidet Sprayer Replacement: passo 3, immagine 1 di 1
    • Place a towel under the tank incase of any water drops.
  4. Handheld Toilet Bidet Sprayer Replacement: passo 4, immagine 1 di 1
    • Unscrew the water supply line from the T-connector by turning the knob counterclockwise.
  5. Handheld Toilet Bidet Sprayer Replacement: passo 5, immagine 1 di 1
    • Unscrew the hose from the T-connector by turning the knob counterclockwise.
  6. Handheld Toilet Bidet Sprayer Replacement: passo 6, immagine 1 di 1
    • Unscrew the T-connector from the toilet by turning the knob counterclockwise.
  7. Handheld Toilet Bidet Sprayer Replacement: passo 7, immagine 1 di 3 Handheld Toilet Bidet Sprayer Replacement: passo 7, immagine 2 di 3 Handheld Toilet Bidet Sprayer Replacement: passo 7, immagine 3 di 3
    • Install the toilet sprayer's rubber on the water supply hose from the side that is causing a water leak. This will stop water leaking from the hose.
  8. Handheld Toilet Bidet Sprayer Replacement: passo 8, immagine 1 di 1
    • Screw the T-connector back on the toilet by turning the knob clockwise.
    • Be careful not to cross the threads.
  9. Handheld Toilet Bidet Sprayer Replacement: passo 9, immagine 1 di 1
    • Screw the water supply nut onto the bottom of the T-connector by turning the knob clockwise. Make sure it is firmly hand tight.
  10. Handheld Toilet Bidet Sprayer Replacement: passo 10, immagine 1 di 1
    • Screw the water supply hose back on the T-connector by turning the knob clockwise. Be sure not to over tighten the nut.
  11. Handheld Toilet Bidet Sprayer Replacement: passo 11, immagine 1 di 1
    • Turn on the toilet water valve by turning the knob counterclockwise. now, you can test your water and spray it through the hose. Make sure there is no water leaking.
Linea Traguardo
Altre 2 persone hanno completato questa guida.
2 Commenti
If this is used as a bidet, wouldn’t the water be awfully cold? Almost too invigorating. If just used to help clean the toilet, okay.
Pete
Pete Chisteckoff - Replica
Same concern.
Nuke Engineer -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 29
Tutti i Tempi: 10,462
