Salta al contenuto principale
HUAWEI HONOR 5X SD Card Replacement
Collier Summers
Collier Summers e un altro collaboratore
Ultimo aggiornamento il September 2, 2021
1 minuto
Facile
Introduzione
Vai al passo 1
The SD card contains the external storage in your device. This guide is relatively simple, so if you need to replace the SD card in your device, please use this guide.
Cosa ti serve
Strumenti
  1. HUAWEI HONOR 5X SD Card Replacement, SD Card: passo 1, immagine 1 di 1
    • Using the SD/SIM card removing tool, press inward until the tray ejects.
    • Make sure phone is turned off, and unplugged from power sources.
  2. HUAWEI HONOR 5X SD Card Replacement: passo 2, immagine 1 di 1
    • Remove the old SD/SIM card.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 7
Tutti i Tempi: 276
