Salta al contenuto principale
HP TouchSmart 15-r015dx Keyboard Replacement
Jacob Kleinsorge
Jacob Kleinsorge e 11 altri collaboratori
Ultimo aggiornamento il June 8, 2023
5 minuti
Facile
Introduzione
Vai al passo 1
Easy five minute guide, with pictures on how to replace the original keyboard on a HP TouchSmart 15-r015dx laptop to a Cruus NSK-CN6SC keyboard. Replacement may be needed for damaged or broken keyboards. Change your keyboard with three easy steps and using two tools, 1 iFixit Opening Tool and 1 Phillips #00 Screwdriver. Learn how to replace the keyboard on your laptop and spend less than $8 on tools.
Cosa ti serve
Strumenti
  1. HP TouchSmart 15-r015dx Keyboard Replacement, Keyboard: passo 1, immagine 1 di 2 HP TouchSmart 15-r015dx Keyboard Replacement, Keyboard: passo 1, immagine 2 di 2
    • Using your Phillips #00 screwdriver, remove the two screws to loosen the fittings of the keyboard.
    • One of the screws lies in the label.
  2. HP TouchSmart 15-r015dx Keyboard Replacement: passo 2, immagine 1 di 3 HP TouchSmart 15-r015dx Keyboard Replacement: passo 2, immagine 2 di 3 HP TouchSmart 15-r015dx Keyboard Replacement: passo 2, immagine 3 di 3
    • Flip the laptop over to view the top and lift the screen up.
    • There are sixteen clips holding the keyboard in place. Gently pry up each clip using a plastic opening tool. Once all clips are loose, lift the keyboard from the computer.
    • Do NOT pull the keyboard up more than 2-3 inches as there is a film-material connecting the keyboard to the laptop.
  3. HP TouchSmart 15-r015dx Keyboard Replacement: passo 3, immagine 1 di 3 HP TouchSmart 15-r015dx Keyboard Replacement: passo 3, immagine 2 di 3 HP TouchSmart 15-r015dx Keyboard Replacement: passo 3, immagine 3 di 3
    • There is a small black latch holding the film-material in place.
    • Flip the black latch up to release the film-material. Once flipped up, simply pull the film-material out from the laptop to release the keyboard.
    • There are tiny prongs on the ribbon; it must be carefully removed and upon re-installation the prongs must be lined up exactly in each tiny track in order for the keyboard to work.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 16-4, Watkins Winter 2015 Membro di USF Tampa, Team 16-4, Watkins Winter 2015
USFT-WATKINS-W15S16G4
4 Membri
6 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 23
Tutti i Tempi: 3,063
