Salta al contenuto principale
HP Stream 11-d008TU Battery Connector Unplugging
Joel Taylor
Joel Taylor e un altro collaboratore
Ultimo aggiornamento il June 24, 2020
35 minuti
Moderato
Foto Azione
Necessarie Immagini Migliori
Necessarie Più Immagini
Guida fornita dalla comunità
Cosa ti serve
Strumenti
Mostra di più…
  1. HP Stream 11-d008TU Battery Connector Unplugging, Rubber Feet Removal: passo 1, immagine 1 di 3 HP Stream 11-d008TU Battery Connector Unplugging, Rubber Feet Removal: passo 1, immagine 2 di 3 HP Stream 11-d008TU Battery Connector Unplugging, Rubber Feet Removal: passo 1, immagine 3 di 3
    • Use a prying tool to pry the 2 rubber feet off closest to the hinge of the device
    • Repeat this process for the other side of the device
    • The bottom rubber feet do not have hidden screws underneath them, and as such, they are unnecessary to remove
  2. HP Stream 11-d008TU Battery Connector Unplugging, Screw removal: passo 2, immagine 1 di 2 HP Stream 11-d008TU Battery Connector Unplugging, Screw removal: passo 2, immagine 2 di 2
    • Remove the 11x 5mm Phillips PH-0 screws (circled)
  3. HP Stream 11-d008TU Battery Connector Unplugging, Keyboard Unclipping: passo 3, immagine 1 di 3 HP Stream 11-d008TU Battery Connector Unplugging, Keyboard Unclipping: passo 3, immagine 2 di 3 HP Stream 11-d008TU Battery Connector Unplugging, Keyboard Unclipping: passo 3, immagine 3 di 3
    • Use your finger to pry the outer blue shell over the keyboard
    • Continue this process around the edges of the device
    • You may have to use a prying tool to pry the harder edges such as around the I/O ports
    • Do not lift the keyboard once all the clips are undone, as there are still various cables connected
  4. HP Stream 11-d008TU Battery Connector Unplugging, Keyboard removal: passo 4, immagine 1 di 3 HP Stream 11-d008TU Battery Connector Unplugging, Keyboard removal: passo 4, immagine 2 di 3 HP Stream 11-d008TU Battery Connector Unplugging, Keyboard removal: passo 4, immagine 3 di 3
    • Disconnect the power button connector by peeling back the protective tape, using your fingernail to flip the white retaining clip back, and pulling the ribbon cable out
    • Disconnect the touchpad connector by using your fingernail to flip the black retaining clip back, and pulling the ribbon cable out
    • Disconnect the keyboard connector by using your fingernail to flip the black retaining clip back, and pulling the ribbon cable out
    • Your keyboard assembly is now safe to remove
  5. HP Stream 11-d008TU Battery Connector Unplugging, Battery Connector: passo 5, immagine 1 di 3 HP Stream 11-d008TU Battery Connector Unplugging, Battery Connector: passo 5, immagine 2 di 3 HP Stream 11-d008TU Battery Connector Unplugging, Battery Connector: passo 5, immagine 3 di 3
    • Locate the white plastic connector on the motherboard
    • Peel back the black tape holding the cable's wires in place
    • Pull the white connector out by puling the white plastic away from the connector
    • Do not grab the connector by the wires
Conclusione
Joel Taylor
Membro da: 03/07/20
1.298 Reputazione
8 Guide realizzate
Australia Membro di Australia
Community
4 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 104
