Salta al contenuto principale
HP Split x2 13-g210dx Battery Replacement
Darian Devries
Darian Devries e 4 altri collaboratori
Ultimo aggiornamento il May 7, 2024
10 minuti
Moderato
Foto Azione
Necessarie Più Immagini
Introduzione
Vai al passo 1
If the laptop only powers on while plugged in, then the battery is defective. Use this guide to access, remove, and replace your battery. Separating the back panel from the clips on the device will require the use of force.
Cosa ti serve
Strumenti
Mostra di più…
  1. HP Split x2 13-g210dx Battery Replacement, Back Panel: passo 1, immagine 1 di 1
    • Carefully peel off the felt cover that is found beneath the display along the bottom of the device.
    • Use a spudger to gently scrape away the padding that hides the screws in each of the four locations.
    • Remove the four 4-mm Phillips #0 screws.
    • Run a spudger along the crease of the entire laptop and slowly pry off the back panel of the device, beginning with the bottom edge.
    • You will hear popping noises as the clips separate from each other.
  2. HP Split x2 13-g210dx Battery Replacement, Battery: passo 2, immagine 1 di 1
    • Remove the three 6-mm Phillips #0 screws.
  3. HP Split x2 13-g210dx Battery Replacement: passo 3, immagine 1 di 2 HP Split x2 13-g210dx Battery Replacement: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Remove the white connector clip from the connector port using a sturdy tweezers.
  4. HP Split x2 13-g210dx Battery Replacement: passo 4, immagine 1 di 2 HP Split x2 13-g210dx Battery Replacement: passo 4, immagine 2 di 2
    • Lift the battery away from the device.
Conclusione
Altre 5 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 41
Tutti i Tempi: 2,243
