Salta al contenuto principale
HP ProBook x360 11 G5 EE Wireless Card Replacement
Michelle Pina
Michelle Pina e un altro collaboratore
Ultimo aggiornamento il December 27, 2021
15 - 25 minuti
Moderato
Introduzione
Vai al passo 1
The guide will show how to replace the wireless card in your HP ProBook x360 11 G5 EE laptop. The Wi-Fi card allows you to connect to the internet wirelessly. If the laptop’s Wi-Fi keeps on connecting and disconnecting, has a weak connection, or simply cannot find any networks regardless of troubleshooting, you may have a faulty wireless card.
Cosa ti serve
Strumenti
Mostra di più…
  1. HP ProBook x360 11 G5 EE Wireless Card Replacement, Keyboard Assembly: passo 1, immagine 1 di 3 HP ProBook x360 11 G5 EE Wireless Card Replacement, Keyboard Assembly: passo 1, immagine 2 di 3 HP ProBook x360 11 G5 EE Wireless Card Replacement, Keyboard Assembly: passo 1, immagine 3 di 3
    • Remove the 4.1 mm screws with a T5 Torx screwdriver.
    • Remove the 4.1 mm screws using a JIS #0 screwdriver.
  2. HP ProBook x360 11 G5 EE Wireless Card Replacement: passo 2, immagine 1 di 1
    • Use an opening pick to pry the corners of the keyboard deck.
  3. HP ProBook x360 11 G5 EE Wireless Card Replacement: passo 3, immagine 1 di 3 HP ProBook x360 11 G5 EE Wireless Card Replacement: passo 3, immagine 2 di 3 HP ProBook x360 11 G5 EE Wireless Card Replacement: passo 3, immagine 3 di 3
    • Use an opening pick or opening tool to pry around the sides of the keyboard assembly.
  4. HP ProBook x360 11 G5 EE Wireless Card Replacement: passo 4, immagine 1 di 3 HP ProBook x360 11 G5 EE Wireless Card Replacement: passo 4, immagine 2 di 3 HP ProBook x360 11 G5 EE Wireless Card Replacement: passo 4, immagine 3 di 3
    • Lift the keyboard assembly to expose two ribbon cables.
    • Lift the two plastic tabs that hold the cables in place on the motherboard
    • Slide the ribbon cables out of each connector.
  5. HP ProBook x360 11 G5 EE Wireless Card Replacement: passo 5, immagine 1 di 2 HP ProBook x360 11 G5 EE Wireless Card Replacement: passo 5, immagine 2 di 2
    • Remove the keyboard assembly from the rest of the computer.
  6. HP ProBook x360 11 G5 EE Wireless Card Replacement, Battery: passo 6, immagine 1 di 2 HP ProBook x360 11 G5 EE Wireless Card Replacement, Battery: passo 6, immagine 2 di 2
    • Remove the four 3 mm screws from the battery with the JIS #0 screwdriver.
  7. HP ProBook x360 11 G5 EE Wireless Card Replacement: passo 7, immagine 1 di 3 HP ProBook x360 11 G5 EE Wireless Card Replacement: passo 7, immagine 2 di 3 HP ProBook x360 11 G5 EE Wireless Card Replacement: passo 7, immagine 3 di 3
    • Pry the battery up from the laptop using an opening pick.
    • Lift the battery out of its place.
  8. HP ProBook x360 11 G5 EE Wireless Card Replacement, Wireless Card: passo 8, immagine 1 di 3 HP ProBook x360 11 G5 EE Wireless Card Replacement, Wireless Card: passo 8, immagine 2 di 3 HP ProBook x360 11 G5 EE Wireless Card Replacement, Wireless Card: passo 8, immagine 3 di 3
    • Disconnect the ribbon wire from the motherboard by lifting the small flap that holds it in place.
  9. HP ProBook x360 11 G5 EE Wireless Card Replacement: passo 9, immagine 1 di 2 HP ProBook x360 11 G5 EE Wireless Card Replacement: passo 9, immagine 2 di 2
    • Remove both antenna cables that are attached to the wireless card.
  10. HP ProBook x360 11 G5 EE Wireless Card Replacement: passo 10, immagine 1 di 3 HP ProBook x360 11 G5 EE Wireless Card Replacement: passo 10, immagine 2 di 3 HP ProBook x360 11 G5 EE Wireless Card Replacement: passo 10, immagine 3 di 3
    • Remove the 3 mm screw that secures the wireless card using a JIS #0 screwdriver.
    • Slide the wireless card out of the slot gently.
    • Make sure not to pull it directly up as it can break.
Conclusione
Michelle Pina
Membro da: 10/26/21
506 Reputazione
4 Guide realizzate
Gateway, Team 1-4, Pee Fall 2021 Membro di Gateway, Team 1-4, Pee Fall 2021
GCC-PEE-F21S1G4
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 17
Tutti i Tempi: 579
