Salta al contenuto principale
HP ProBook x360 11 G5 EE Display Panel Replacement
Michelle Pina
Michelle Pina e un altro collaboratore
Ultimo aggiornamento il December 27, 2021
20 - 45 minuti
Moderato
Introduzione Migliore
Introduzione
Vai al passo 1
In the guide, we will be covering how to replace the touchscreen display panel of an HP ProBook x360 11 G5 Education Edition. The display of a laptop is vital to a user since it allows them to perform the software functions they need.
Cosa ti serve
Strumenti
Mostra di più…
  1. HP ProBook x360 11 G5 EE Display Panel Replacement, Keyboard Assembly: passo 1, immagine 1 di 3 HP ProBook x360 11 G5 EE Display Panel Replacement, Keyboard Assembly: passo 1, immagine 2 di 3 HP ProBook x360 11 G5 EE Display Panel Replacement, Keyboard Assembly: passo 1, immagine 3 di 3
    • Remove the 4.1 mm screws with a T5 Torx screwdriver.
    • Remove the 4.1 mm screws using a JIS #0 screwdriver.
  2. HP ProBook x360 11 G5 EE Display Panel Replacement: passo 2, immagine 1 di 1
    • Use an opening pick to pry the corners of the keyboard deck.
  3. HP ProBook x360 11 G5 EE Display Panel Replacement: passo 3, immagine 1 di 3 HP ProBook x360 11 G5 EE Display Panel Replacement: passo 3, immagine 2 di 3 HP ProBook x360 11 G5 EE Display Panel Replacement: passo 3, immagine 3 di 3
    • Use an opening pick or opening tool to pry around the sides of the keyboard assembly.
  4. HP ProBook x360 11 G5 EE Display Panel Replacement: passo 4, immagine 1 di 3 HP ProBook x360 11 G5 EE Display Panel Replacement: passo 4, immagine 2 di 3 HP ProBook x360 11 G5 EE Display Panel Replacement: passo 4, immagine 3 di 3
    • Lift the keyboard assembly to expose two ribbon cables.
    • Lift the two plastic tabs that hold the cables in place on the motherboard
    • Slide the ribbon cables out of each connector.
  5. HP ProBook x360 11 G5 EE Display Panel Replacement: passo 5, immagine 1 di 2 HP ProBook x360 11 G5 EE Display Panel Replacement: passo 5, immagine 2 di 2
    • Remove the keyboard assembly from the rest of the computer.
  6. HP ProBook x360 11 G5 EE Display Panel Replacement, Battery: passo 6, immagine 1 di 2 HP ProBook x360 11 G5 EE Display Panel Replacement, Battery: passo 6, immagine 2 di 2
    • Remove the four 3 mm screws from the battery with the JIS #0 screwdriver.
  7. HP ProBook x360 11 G5 EE Display Panel Replacement: passo 7, immagine 1 di 3 HP ProBook x360 11 G5 EE Display Panel Replacement: passo 7, immagine 2 di 3 HP ProBook x360 11 G5 EE Display Panel Replacement: passo 7, immagine 3 di 3
    • Pry the battery up from the laptop using an opening pick.
    • Lift the battery out of its place.
  8. HP ProBook x360 11 G5 EE Display Panel Replacement, Display Panel: passo 8, immagine 1 di 3 HP ProBook x360 11 G5 EE Display Panel Replacement, Display Panel: passo 8, immagine 2 di 3 HP ProBook x360 11 G5 EE Display Panel Replacement, Display Panel: passo 8, immagine 3 di 3
    • Use the opening pick and metal spudger to pry open the display cover.
  9. HP ProBook x360 11 G5 EE Display Panel Replacement: passo 9, immagine 1 di 2 HP ProBook x360 11 G5 EE Display Panel Replacement: passo 9, immagine 2 di 2
    • Remove the ribbon wire that is attached to the display cover to fully detach it.
  10. HP ProBook x360 11 G5 EE Display Panel Replacement: passo 10, immagine 1 di 2 HP ProBook x360 11 G5 EE Display Panel Replacement: passo 10, immagine 2 di 2
    • Remove the four 2.3 mm screws holding the screen in place with the JIS #0 screwdriver.
  11. HP ProBook x360 11 G5 EE Display Panel Replacement: passo 11, immagine 1 di 3 HP ProBook x360 11 G5 EE Display Panel Replacement: passo 11, immagine 2 di 3 HP ProBook x360 11 G5 EE Display Panel Replacement: passo 11, immagine 3 di 3
    • Lift the screen to disconnect the wire attaching it to the laptop.
    • Remove the display panel from the rest of the laptop.
Conclusione
Altre 2 persone hanno completato questa guida.
Michelle Pina
Membro da: 10/26/21
506 Reputazione
4 Guide realizzate
Gateway, Team 1-4, Pee Fall 2021 Membro di Gateway, Team 1-4, Pee Fall 2021
GCC-PEE-F21S1G4
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 76
Tutti i Tempi: 3,149
