Salta al contenuto principale
HP ProBook 455 G7 RAM Replacement
Cosa ti serve
  1. HP ProBook 455 G7 RAM Replacement, Lower Case: passo 1, immagine 1 di 1
    • Before beginning, completely power off the laptop and unplug the charger and any peripheries.
    • Flip the laptop over so the lower case is facing up.
    • Use a Phillips #1 screwdriver to remove the seven 8 mm-long screws securing the lower case.
    Chiedi a FixBot
    Aggiungi Commento
  2. HP ProBook 455 G7 RAM Replacement: passo 2, immagine 1 di 3 HP ProBook 455 G7 RAM Replacement: passo 2, immagine 2 di 3 HP ProBook 455 G7 RAM Replacement: passo 2, immagine 3 di 3
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry around the entire perimeter until the lower case fully releases.
    • Lift and remove the lower case.
    Chiedi a FixBot
    Aggiungi Commento
  3. HP ProBook 455 G7 RAM Replacement, Battery: passo 3, immagine 1 di 3 HP ProBook 455 G7 RAM Replacement, Battery: passo 3, immagine 2 di 3 HP ProBook 455 G7 RAM Replacement, Battery: passo 3, immagine 3 di 3
    • Use a Phillips #1 screwdriver to remove the three 4 mm-long screws securing the battery.
    • Carefully lift the battery and remove it from the laptop.
    Chiedi a FixBot
    Aggiungi Commento
  4. HP ProBook 455 G7 RAM Replacement, RAM: passo 4, immagine 1 di 1
    • Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
    Chiedi a FixBot
    Aggiungi Commento
  5. HP ProBook 455 G7 RAM Replacement: passo 5, immagine 1 di 1
    • The RAM stick should pop up at an angle.
    Chiedi a FixBot
    Aggiungi Commento
  6. HP ProBook 455 G7 RAM Replacement: passo 6, immagine 1 di 1
    • Carefully pull the module directly out of its socket.
    • Align the notch on the new RAM module with the slot in the connector.
    • Slide the module in at an angle, then press down until it clicks into place.
    • The HP ProBook 455 G7 typically supports DDR4 SO-DIMM RAM up to 32 GB (2 × 16 GB). Make sure both sticks are properly seated before reassembling.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
UMass Dartmouth, Team 1-6, Botvin Fall 2025 Membro di UMass Dartmouth, Team 1-6, Botvin Fall 2025
UMASSD-BOTVIN-F25S1G6
3 Membri
6 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 23
Tutti i Tempi: 147
