Salta al contenuto principale
HP Pavilion dv7t-7000 Speaker Replacement
Nabin Bhatta
Nabin Bhatta e un altro collaboratore
Ultimo aggiornamento il June 13, 2018
30 minuti
Moderato
Introduzione Migliore
Introduzione
Vai al passo 1
How to replace the speaker on a HP Pavilion dv7t-7000 laptop.
Cosa ti serve
Strumenti
  1. HP Pavilion dv7t-7000 Speaker Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the computer off and disconnect if from all power sources.
  2. HP Pavilion dv7t-7000 Speaker Replacement: passo 2, immagine 1 di 1
    • Slide the battery release switch to the left.
  3. HP Pavilion dv7t-7000 Speaker Replacement: passo 3, immagine 1 di 1
    • Hold the release switch all of the way to the left and your other hand to pull the battery out.
  4. HP Pavilion dv7t-7000 Speaker Replacement, Back Panel: passo 4, immagine 1 di 1
    • Unscrew the single Phillips #00 screw.
    • Screw will not come out, it is connected to the panel
  5. HP Pavilion dv7t-7000 Speaker Replacement: passo 5, immagine 1 di 2 HP Pavilion dv7t-7000 Speaker Replacement: passo 5, immagine 2 di 2
    • Remove service hatch by sliding away from the computer and lifting up.
  6. HP Pavilion dv7t-7000 Speaker Replacement, Keyboard: passo 6, immagine 1 di 2 HP Pavilion dv7t-7000 Speaker Replacement, Keyboard: passo 6, immagine 2 di 2
    • Remove the single Phillips #00 screw.
    • Flip the laptop over.
  7. HP Pavilion dv7t-7000 Speaker Replacement: passo 7, immagine 1 di 3 HP Pavilion dv7t-7000 Speaker Replacement: passo 7, immagine 2 di 3 HP Pavilion dv7t-7000 Speaker Replacement: passo 7, immagine 3 di 3
    • Wedge a spudger in between the keyboard and the upper bezel (nearest the screen).
    • Pry upward to release the keyboard clips.
    • The keyboard is plugged into the motherboard, so be careful not to pull out while lifting keyboard.
  8. HP Pavilion dv7t-7000 Speaker Replacement: passo 8, immagine 1 di 1
    • Use the flat end of a spudger to flip up the black tab on the ZIF connectors.
    • Pull the ribbon cables out of the ZIF connectors.
    • Remove the keyboard.
  9. HP Pavilion dv7t-7000 Speaker Replacement, Speaker: passo 9, immagine 1 di 3 HP Pavilion dv7t-7000 Speaker Replacement, Speaker: passo 9, immagine 2 di 3 HP Pavilion dv7t-7000 Speaker Replacement, Speaker: passo 9, immagine 3 di 3
    • Use Phillips #00 to unscrew the screw and take off the front panel.
  10. HP Pavilion dv7t-7000 Speaker Replacement: passo 10, immagine 1 di 2 HP Pavilion dv7t-7000 Speaker Replacement: passo 10, immagine 2 di 2
    • The speaker is located at the back side of the front panel.
    • Unscrew two screws located at the speaker.
  11. HP Pavilion dv7t-7000 Speaker Replacement: passo 11, immagine 1 di 1
    • Pull out the speakers to remove.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,406
