Salta al contenuto principale
HP Pavilion dv7-3065dx RAM Replacement
Jonathan Winkler
Jonathan Winkler e un altro collaboratore
Ultimo aggiornamento il May 11, 2017
8 minuti
Moderato
Foto Azione
Necessarie Immagini Migliori
Introduzione
Vai al passo 1
RAM is an essential Computing Module. Having faulty RAM will cause your computer to not work, and increasing the amount of RAM can make your computer work faster. The HP Pavilion dv7-3065dx can utilize a maximum of 8 GB of total RAM, and comes with a standard 4GB.
Cosa ti serve
  1. HP Pavilion dv7-3065dx RAM Replacement, Battery: passo 1, immagine 1 di 2 HP Pavilion dv7-3065dx RAM Replacement, Battery: passo 1, immagine 2 di 2
    • Turn off the device before removing the battery.
    • Place the laptop upside down on a flat surface so that the bottom is facing up.
    • The battery is the long rectangle above the latch.
  2. HP Pavilion dv7-3065dx RAM Replacement: passo 2, immagine 1 di 1
    • Slide the battery latch to the left to release the battery.
  3. HP Pavilion dv7-3065dx RAM Replacement: passo 3, immagine 1 di 2 HP Pavilion dv7-3065dx RAM Replacement: passo 3, immagine 2 di 2
    • Carefully pull out the battery while holding the latch to the open position with your finger.
  4. HP Pavilion dv7-3065dx RAM Replacement, RAM: passo 4, immagine 1 di 1
    • Remove the four circled screws using a #1 philips head screwdriver
    • Note: Be sure to leave the screws in the pannel
    • Pry off cover and place to the side.
  5. HP Pavilion dv7-3065dx RAM Replacement: passo 5, immagine 1 di 1
    • The RAM modules will be found on the right side of the access panel
    • CAUTION - The RAM modules are sensitive to electrostatic discharge. It is recommended to wear an anti static bracelet while handling the RAM.
  6. HP Pavilion dv7-3065dx RAM Replacement: passo 6, immagine 1 di 2 HP Pavilion dv7-3065dx RAM Replacement: passo 6, immagine 2 di 2
    • To remove RAM modules, pry metal tabs out of the modules, and pull ram out (Starting from the top RAM module).
    • Note: The RAM Modules pop out away from the motherboard. In order to replace them, slot the gold plated end into the terminal and push down towards the motherboard.
Conclusione
Altre 3 persone hanno completato questa guida.
Ohio State, Team 1-5, Wilder Spring 2017 Membro di Ohio State, Team 1-5, Wilder Spring 2017
OSU-WILDER-S17S1G5
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,350
