Salta al contenuto principale
HP Pavilion 15-b109wm Motherboard Replacement
Enrico Miozzo
Enrico Miozzo e 3 altri collaboratori
Ultimo aggiornamento il January 7, 2020
25 - 35 minuti
Difficile
Introduzione
Vai al passo 1
This replacement guide will show how to replace the Motherboard of an HP Pavilion 15-b109wm. This process will take between 25-35 minutes, if done correctly. Remember to take your time and do the steps correctly and gently to avoid parts breakage.
For this guide you will need a heavy-duty spudger, a JIS driver set and an iFixtit opening tool. Some parts of this guide require some force to pop open, be careful not to brake or damage any parts when applying force.
Cosa ti serve
Strumenti
Mostra di più…
  1. HP Pavilion 15-b109wm Motherboard Replacement, Hard Drive: passo 1, immagine 1 di 3 HP Pavilion 15-b109wm Motherboard Replacement, Hard Drive: passo 1, immagine 2 di 3 HP Pavilion 15-b109wm Motherboard Replacement, Hard Drive: passo 1, immagine 3 di 3
    • Disconnect the cables to the motherboard.
  2. HP Pavilion 15-b109wm Motherboard Replacement: passo 2, immagine 1 di 2 HP Pavilion 15-b109wm Motherboard Replacement: passo 2, immagine 2 di 2
    • Remove the hard drive.
  3. HP Pavilion 15-b109wm Motherboard Replacement, Motherboard: passo 3, immagine 1 di 2 HP Pavilion 15-b109wm Motherboard Replacement, Motherboard: passo 3, immagine 2 di 2
    • Unclip the WLAN cable out of its place to allow the motherboard room to move.
  4. HP Pavilion 15-b109wm Motherboard Replacement: passo 4, immagine 1 di 2 HP Pavilion 15-b109wm Motherboard Replacement: passo 4, immagine 2 di 2
    • Detach the power connector cable.
  5. HP Pavilion 15-b109wm Motherboard Replacement: passo 5, immagine 1 di 2 HP Pavilion 15-b109wm Motherboard Replacement: passo 5, immagine 2 di 2
    • Remove the motherboard from the device.
Conclusione
To reassemble your device work in the reverse order, make sure all the screws are in their required hole before assembling the next part.
Enrico Miozzo
Membro da: 11/07/19
244 Reputazione
2 Guide realizzate
IUPUI, Team S2-G4, Harley Fall 2019 Membro di IUPUI, Team S2-G4, Harley Fall 2019
IUPUI-HARLEY-F19S2G4
3 Membri
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 366
