Salta al contenuto principale
HP Pavilion 14-bk061st Screen Replacement
Mehrab Daemi
Mehrab Daemi e 3 altri collaboratori
Ultimo aggiornamento il June 23, 2020
5 - 10 minuti
Moderato
Introduzione
Vai al passo 1
Using this guide will help you in replacing the screen in your HP Pavilion 14-bk061st.
The screen is an important part of all laptops. Some may consider replacing the screen once issues arise during use such as cracked screens after a fall or vertical or horizontal lines sometimes caused by a loose or frayed video cable.
Cosa ti serve
Strumenti
Mostra di più…
  1. HP Pavilion 14-bk061st Screen Replacement, Back Panel: passo 1, immagine 1 di 2 HP Pavilion 14-bk061st Screen Replacement, Back Panel: passo 1, immagine 2 di 2
    • Remove the three 5.7 JIS #1 screws from the bottom of the laptop.
    • Remove the two 6.7mm JIS #1 screws from underneath the feet of the laptop close to the exhaust vent.
  2. HP Pavilion 14-bk061st Screen Replacement: passo 2, immagine 1 di 1
    • Unclip the back plate using a plastic opening tool.
  3. HP Pavilion 14-bk061st Screen Replacement: passo 3, immagine 1 di 1
    • Carefully remove the back plate from the laptop.
  4. HP Pavilion 14-bk061st Screen Replacement, Screen: passo 4, immagine 1 di 2 HP Pavilion 14-bk061st Screen Replacement, Screen: passo 4, immagine 2 di 2
    • Remove the five JIS #1 screws that attach the hinges of the screen to the casing of the laptop.
  5. HP Pavilion 14-bk061st Screen Replacement: passo 5, immagine 1 di 2 HP Pavilion 14-bk061st Screen Replacement: passo 5, immagine 2 di 2
    • Carefully lift the hinges from the encasing and lift the bottom half of the laptop away from the screen.
  6. HP Pavilion 14-bk061st Screen Replacement: passo 6, immagine 1 di 3 HP Pavilion 14-bk061st Screen Replacement: passo 6, immagine 2 di 3 HP Pavilion 14-bk061st Screen Replacement: passo 6, immagine 3 di 3
    • Use the metal spudger to carefully pry off the plastic encasing around the monitor.
    • Use the outside of the screen to remove the plastic encasing to avoid damaging the screen itself.
  7. HP Pavilion 14-bk061st Screen Replacement: passo 7, immagine 1 di 2 HP Pavilion 14-bk061st Screen Replacement: passo 7, immagine 2 di 2
    • Remove the four JIS #1 screws holding the screen in place.
  8. HP Pavilion 14-bk061st Screen Replacement: passo 8, immagine 1 di 3 HP Pavilion 14-bk061st Screen Replacement: passo 8, immagine 2 di 3 HP Pavilion 14-bk061st Screen Replacement: passo 8, immagine 3 di 3
    • Carefully remove the sticker covering the wire that connects the screen to the motherboard.
    • Disconnect the cable that is connected to the screen.
  9. HP Pavilion 14-bk061st Screen Replacement: passo 9, immagine 1 di 1
    • Remove the screen from the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 17
Tutti i Tempi: 940
