Salta al contenuto principale
HP Pavilion 11 x360 Speakers Replacement
Natalie
Natalie e 5 altri collaboratori
Ultimo aggiornamento il December 25, 2023
10 - 15 minuti
Facile
Introduzione
Vai al passo 1
Unplug your device from any power source and turn off your laptop before beginning.
Cosa ti serve
Strumenti
  • Spudger
    Spudger
  • Phillips #0 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
Mostra di più…
  1. HP Pavilion 11 x360 Speakers Replacement, Remove Screws: passo 1, immagine 1 di 2 HP Pavilion 11 x360 Speakers Replacement, Remove Screws: passo 1, immagine 2 di 2
    • Use the spudger to pry off the two rubber feet near the hinge of the laptop. This will reveal two hidden 9mm screws.
    • You must remove eleven screws.
    • Four 9mm screws with the PH0 screwdriver.
    • Seven 6mm screws with the PH0 screwdriver.
  2. HP Pavilion 11 x360 Speakers Replacement, Remove Backing: passo 2, immagine 1 di 3 HP Pavilion 11 x360 Speakers Replacement, Remove Backing: passo 2, immagine 2 di 3 HP Pavilion 11 x360 Speakers Replacement, Remove Backing: passo 2, immagine 3 di 3
    • Use the spudger to pry the corners of the laptop near the display hinges.
    • Pry around the seam of the laptop with the plastic opening tool until the backing begins to pull apart.
    • When you lift the bottom cover, there is a cable connected between the motherboard and the bottom cover. Be careful not to pull the cable loose!
  3. HP Pavilion 11 x360 Speakers Replacement, Detach Cable: passo 3, immagine 1 di 2 HP Pavilion 11 x360 Speakers Replacement, Detach Cable: passo 3, immagine 2 di 2
    • Use the plastic opening tool to lift the white tab up at the connection.
    • Pull the cable outwards.
  4. HP Pavilion 11 x360 Speakers Replacement, Battery: passo 4, immagine 1 di 1
    • Remove the four 6mm screws from the battery with the PH0 screwdriver.
  5. HP Pavilion 11 x360 Speakers Replacement: passo 5, immagine 1 di 3 HP Pavilion 11 x360 Speakers Replacement: passo 5, immagine 2 di 3 HP Pavilion 11 x360 Speakers Replacement: passo 5, immagine 3 di 3
    • Use the spudger to pry up the blue/white speaker wires that are routed beside the battery.
  6. HP Pavilion 11 x360 Speakers Replacement: passo 6, immagine 1 di 2 HP Pavilion 11 x360 Speakers Replacement: passo 6, immagine 2 di 2
    • Remove the battery cable from the motherboard by gently pulling out on the black part of the cable closest to the white tab.
  7. HP Pavilion 11 x360 Speakers Replacement: passo 7, immagine 1 di 2 HP Pavilion 11 x360 Speakers Replacement: passo 7, immagine 2 di 2
    • Remove the battery.
  8. HP Pavilion 11 x360 Speakers Replacement, Speakers: passo 8, immagine 1 di 3 HP Pavilion 11 x360 Speakers Replacement, Speakers: passo 8, immagine 2 di 3 HP Pavilion 11 x360 Speakers Replacement, Speakers: passo 8, immagine 3 di 3
    • Remove two 6mm screws on each speaker with the PH0 screwdriver.
  9. HP Pavilion 11 x360 Speakers Replacement: passo 9, immagine 1 di 3 HP Pavilion 11 x360 Speakers Replacement: passo 9, immagine 2 di 3 HP Pavilion 11 x360 Speakers Replacement: passo 9, immagine 3 di 3
    • Disconnect the black cable that attaches the speakers to the motherboard by gently pulling the cable outward.
    • Remove the speakers.
Conclusione
Altre 2 persone hanno completato questa guida.
Natalie
Membro da: 01/22/15
937 Reputazione
4 Guide realizzate
Cal Poly, Team 19-9, Maness Winter 2015 Membro di Cal Poly, Team 19-9, Maness Winter 2015
CPSU-MANESS-W15S19G9
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,723
