Salta al contenuto principale
HP Envy x360 15-bp143cl SSD Replacement
Thomas Schemm
Thomas Schemm e 5 altri collaboratori
Ultimo aggiornamento il December 6, 2022
20 minuti
Facile
Introduzione
Vai al passo 1
There are many different reasons that you may want to replace or upgrade your Solid State Drive (SSD), including improving your machine's boot time and increasing disk storage space. Some similar models of HP Envy laptops do not come with a pre-installed SSD, but can be upgraded through a similar procedure as listed in this guide. Upgrading your mass storage device can help with your boot and operating speeds. One of the main reasons to upgrade is the ability to improve storage capacity without compromising space (Hard Disk Drives (HDDs) are much larger). HDDs also have a significantly higher propensity to failure due to being a magnetic rotary mechanism with many moving parts. The steps outlined in this procedure walk you through replacing the mass storage device in an HP Envy x360 15m-bq021dx laptop with an SSD.
If you're noticing prolonged boot times, energy consumption issues such as poor battery life, or loud fan noise, a failing mass storage device may be your issue. It is important to note that the mass storage device is something that the vast majority of the other components in the laptop rely on, so addressing issues here can prevent a lot of headaches later with other pieces of hardware being over-worked.
This replacement or upgrade does not require any special skills such as soldering.
Cosa ti serve
Kit di riparazione
Questi kit contengono tutti i ricambi e gli strumenti necessari per completare questa guida.
Ricambi
Strumenti
Mostra di più…
  1. HP Envy x360 15-bp143cl SSD Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the laptop over.
    • Peel off the rubber strip closest to the hinges.
  2. HP Envy x360 15-bp143cl SSD Replacement: passo 2, immagine 1 di 1
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the four 6.5mm screws that were underneath the rubber strip.
  3. HP Envy x360 15-bp143cl SSD Replacement: passo 3, immagine 1 di 1
    • Use a Torx T5 screwdriver (T5 bit) to remove the three 5mm screws near the bottom edge of the laptop.
  4. HP Envy x360 15-bp143cl SSD Replacement: passo 4, immagine 1 di 1
    • Lift the back panel to remove it from the laptop.
    • Use an opening tool to pry open the back panel if it does not easily lift apart.
  5. HP Envy x360 15-bp143cl SSD Replacement: passo 5, immagine 1 di 2 HP Envy x360 15-bp143cl SSD Replacement: passo 5, immagine 2 di 2
    • Use a Phillips #1 screwdriver (PH1) to remove the seven 4mm screws indicated by the gray arrows on the battery.
  6. HP Envy x360 15-bp143cl SSD Replacement: passo 6, immagine 1 di 1
    • Pull the battery from the connecting port and lift to remove it from the laptop.
  7. HP Envy x360 15-bp143cl SSD Replacement, SSD: passo 7, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove the single 4 mm screw securing the SSD.
  8. HP Envy x360 15-bp143cl SSD Replacement: passo 8, immagine 1 di 1
    • Pull the SSD directly out its port.
Conclusione
Altre 2 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 31
Ultimi 30 Giorni: 75
Tutti i Tempi: 4,733
