Salta al contenuto principale
HP Envy Ultrabook 4-1043cl Hard Drive Replacement
Shen Zhao
Shen Zhao e 5 altri collaboratori
Ultimo aggiornamento il November 18, 2022
15 minuti
Moderato
Introduzione
Vai al passo 1
This guide is used to help you replace the hard disk drive for HP Envy Ultrabook 4-1043cl. When you accidentally drop your laptop down, it is time to replace a new hard disk drive. This guide provides detailed step by step instructions to ensure your successful replacement. You may need an Ifixit PRO TECH TOOLKIT to remove the screws and unwarp the bottom enclosure. Before you start, make sure the charger is DISCONNECTED, and the laptop is shut down for safety reasons. And always remember to remove the battery before trying to disconnect hard disk drive. You may want to make a copy of the content in a hard disk drive before you remove it. Meanwhile, it is highly recommended that use different containers to place the removed screws from different parts in case you may forget where some screws belong.
Cosa ti serve
Kit di riparazione
Questo kit contiene tutti i ricambi e gli strumenti necessari per completare questa guida.
Ricambi
Strumenti
Mostra di più…
  1. HP Envy Ultrabook 4-1043cl Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the laptop over so the bottom is facing you.
  2. HP Envy Ultrabook 4-1043cl Hard Drive Replacement: passo 2, immagine 1 di 2 HP Envy Ultrabook 4-1043cl Hard Drive Replacement: passo 2, immagine 2 di 2
    • Remove twelve 7.5 mm screws by using the Phillips #00 screwdriver.
  3. HP Envy Ultrabook 4-1043cl Hard Drive Replacement: passo 3, immagine 1 di 1
    • Use plastic opening tool to remove the back cover.
    • You might want to remove it slowly and gently because the back cover is very thin and fragile.
  4. HP Envy Ultrabook 4-1043cl Hard Drive Replacement: passo 4, immagine 1 di 2 HP Envy Ultrabook 4-1043cl Hard Drive Replacement: passo 4, immagine 2 di 2
    • Remove three 4.2mm screws by using the Phillips #00 screwdriver.
  5. HP Envy Ultrabook 4-1043cl Hard Drive Replacement: passo 5, immagine 1 di 2 HP Envy Ultrabook 4-1043cl Hard Drive Replacement: passo 5, immagine 2 di 2
    • Disconnect the battery cable from the motherboard and remove the battery from the device.
  6. HP Envy Ultrabook 4-1043cl Hard Drive Replacement, Hard Drive: passo 6, immagine 1 di 3 HP Envy Ultrabook 4-1043cl Hard Drive Replacement, Hard Drive: passo 6, immagine 2 di 3 HP Envy Ultrabook 4-1043cl Hard Drive Replacement, Hard Drive: passo 6, immagine 3 di 3
    • The hard drive is in the bottom right corner of the device which is packed by a silver metal shell.
    • Use a Phillips #00 screwdriver to remove the four 4.0 mm screws securing the hard drive to the top cover.
  7. HP Envy Ultrabook 4-1043cl Hard Drive Replacement: passo 7, immagine 1 di 2 HP Envy Ultrabook 4-1043cl Hard Drive Replacement: passo 7, immagine 2 di 2
  8. HP Envy Ultrabook 4-1043cl Hard Drive Replacement: passo 8, immagine 1 di 2 HP Envy Ultrabook 4-1043cl Hard Drive Replacement: passo 8, immagine 2 di 2
    • Pull the hard disk drive out of the connector socket and remove it from the device.
Linea Traguardo
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 12
Tutti i Tempi: 695
