Salta al contenuto principale
HP Elitebook 840 G1 RAM Replacement
Ashley Williams
Ashley Williams e 3 altri collaboratori
Ultimo aggiornamento il March 7, 2024
8 minuti
Moderato
Introduzione
Vai al passo 1
Blue screen, computer randomly restarts with no warning, or you wish to increase your memory than replace the RAM in your HP EliteBook 840 G1.
Cosa ti serve
Strumenti
  1. HP Elitebook 840 G1 RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Slide the latch, to the right, away from the lock symbol.
    • Slide the cover away from the latch to remove it.
  2. HP Elitebook 840 G1 RAM Replacement: passo 2, immagine 1 di 1
    • Once the cover is removed you will be able to see the battery and the two latches that hold it in place.
    • The two latches should be pulled back, one of which is spring loaded and must be held in place in order to remove the battery.
  3. HP Elitebook 840 G1 RAM Replacement: passo 3, immagine 1 di 1
    • Battery should easily be lifted up and out.
  4. HP Elitebook 840 G1 RAM Replacement, RAM: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Anti-Static Wrist Strap
    $7.95
    • Identify the RAM and the pull tabs that will be used in the next step.
    • Always use an anti-static wrist strap when working on a computer.
  5. HP Elitebook 840 G1 RAM Replacement: passo 5, immagine 1 di 1
    • Pull back the two tabs on either side of the RAM this will allow the RAM to be removed.
    • When handling a memory module, use care to prevent touching the memory chips on the board. Touching the memory chips could damage or destroy the memory.
  6. HP Elitebook 840 G1 RAM Replacement: passo 6, immagine 1 di 1
    • Pull the RAM stick gently out and up once the tabs have been pulled to the side.
Conclusione
Altre 8 persone hanno completato questa guida.
USF Tampa, Team 5-3, Blackwell Fall 2015 Membro di USF Tampa, Team 5-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G3
4 Membri
19 Guide realizzate
Un commento
Bonjour,
Ce tuto est clair, merci ! :)
christophe.ducard - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 34
Tutti i Tempi: 9,024
