Salta al contenuto principale
HP Elitebook 830 G7 or G8 Top Cover replacement
Marelec IT
Marelec IT e un altro collaboratore
Ultimo aggiornamento il June 15, 2022
30 minuti - 1 ora
Moderato
Pallini!
Guida fornita dalla comunità
Introduzione
Vai al passo 1
Perhaps the keyboard has been damaged or the layout is wrong?
In that case you need to replace the top cover.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. HP Elitebook 830 G7 or G8 Top Cover replacement, Remove the Base Enclosure: passo 1, immagine 1 di 1
    • Flip the notebook.
    • Unscrew the screws.
    • Open the base enclosure using a plastic wedge (a credit card might also work). Follow the direction of the green arrows.
  2. HP Elitebook 830 G7 or G8 Top Cover replacement, Remove battery and motherboard: passo 2, immagine 1 di 3 HP Elitebook 830 G7 or G8 Top Cover replacement, Remove battery and motherboard: passo 2, immagine 2 di 3 HP Elitebook 830 G7 or G8 Top Cover replacement, Remove battery and motherboard: passo 2, immagine 3 di 3
    • Detach the battery using a plastic spudger.
    • Unscrew the battery screws. Be aware not to damage the speaker cables.
    • Now remove the CMOS battery. Beware: it is glued to the enclosure. So remove with care.
    • Remove the SIM slot.
    • Now detach all connections with the mother board (using a plastic spudger). Unscrew the black (mostly flat) screws until the mother board is loose.
    • Put the Display Cables to the top side. In that way the cables aren't damaged when removing the top cover.
    • Remove the loose plastic parts on the motherboard.
  3. HP Elitebook 830 G7 or G8 Top Cover replacement, Remove Top Cover: passo 3, immagine 1 di 2 HP Elitebook 830 G7 or G8 Top Cover replacement, Remove Top Cover: passo 3, immagine 2 di 2
    • Detach the mother board.
    • Unscrew all the remaining components from the top cover.
    • Unscrew the black screws in the top corners until you can separate the top cover and the display.
  4. HP Elitebook 830 G7 or G8 Top Cover replacement, Re-assembly: passo 4, immagine 1 di 2 HP Elitebook 830 G7 or G8 Top Cover replacement, Re-assembly: passo 4, immagine 2 di 2
    • Attach the new Top Cover.
    • Follow the previous steps in reverse order.
    • Beware when closing the Base Enclosure: slide it towards the front at a 30 degree angle until it snaps in place. Screw everything back together. In this way you prevent an open gap at the front side.
Conclusione
To replace the top cover/keyboard, the device needs to be completely disassembled. That takes time but is not that difficult.
Altre 2 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
nl en
100%
Marelec IT ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Documenti Allegati
Marelec IT
Membro da: 03/15/19
219 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 29
Ultimi 30 Giorni: 72
Tutti i Tempi: 3,769
