Salta al contenuto principale
HP EliteBook x360 830 G7 Display Replacement
Jonathan Bond
Jonathan Bond e 4 altri collaboratori
Ultimo aggiornamento il May 18, 2023
10 - 20 minuti
Moderato
Introduzione
Vai al passo 1
This guide will provide guidance on how to replace the display on your HP EliteBook x360 830 G7. Screens are vital for the user operation of your laptop, as it is an essential output in order for a user to see what their computer is doing and/or what they are doing. Water, cracks, and drops are all ways that your screen can become damaged.
Before you begin, remove any cases or screen protectors, disconnect your computer from it's charger (if connected), and then power off your device.
Cosa ti serve
Strumenti
  1. HP EliteBook x360 830 G7 Display Replacement, Remove the display: passo 1, immagine 1 di 3 HP EliteBook x360 830 G7 Display Replacement, Remove the display: passo 1, immagine 2 di 3 HP EliteBook x360 830 G7 Display Replacement, Remove the display: passo 1, immagine 3 di 3
    • Use an opening tool to remove the display from the laptop case. Place it in the area that you see the most give.
    • If you hear the plastic tabs "snapping" free, you should be fine.
    • Be careful not to crack the display.
  2. HP EliteBook x360 830 G7 Display Replacement, Locate the cable connectors: passo 2, immagine 1 di 3 HP EliteBook x360 830 G7 Display Replacement, Locate the cable connectors: passo 2, immagine 2 di 3 HP EliteBook x360 830 G7 Display Replacement, Locate the cable connectors: passo 2, immagine 3 di 3
    • With the screen removed, locate the pair of wires hidden underneath the two pieces of tape.
  3. HP EliteBook x360 830 G7 Display Replacement, Connector bracket: passo 3, immagine 1 di 2 HP EliteBook x360 830 G7 Display Replacement, Connector bracket: passo 3, immagine 2 di 2
    • Use a plastic opening tool or nylon spudger to lift the metal digitizer-connector bracket.
  4. HP EliteBook x360 830 G7 Display Replacement, Disconnect the golden connector: passo 4, immagine 1 di 3 HP EliteBook x360 830 G7 Display Replacement, Disconnect the golden connector: passo 4, immagine 2 di 3 HP EliteBook x360 830 G7 Display Replacement, Disconnect the golden connector: passo 4, immagine 3 di 3
    • Now that the bracket is removed, pull the golden connector away from the silver base.
    • Now, the back of the display should look like this.
  5. HP EliteBook x360 830 G7 Display Replacement, Peel the black piece of tape: passo 5, immagine 1 di 3 HP EliteBook x360 830 G7 Display Replacement, Peel the black piece of tape: passo 5, immagine 2 di 3 HP EliteBook x360 830 G7 Display Replacement, Peel the black piece of tape: passo 5, immagine 3 di 3
    • The next piece of tape that needs to be peeled, but not removed, is highlighted by the red rectangle.
    • Peel but do not remove the black piece of tape.
  6. HP EliteBook x360 830 G7 Display Replacement, Peel the clear piece of tape: passo 6, immagine 1 di 3 HP EliteBook x360 830 G7 Display Replacement, Peel the clear piece of tape: passo 6, immagine 2 di 3 HP EliteBook x360 830 G7 Display Replacement, Peel the clear piece of tape: passo 6, immagine 3 di 3
    • Peel, but do not remove entirely, the clear piece of tape that was underneath the black tape.
  7. HP EliteBook x360 830 G7 Display Replacement, Small ribbon cable connector: passo 7, immagine 1 di 3 HP EliteBook x360 830 G7 Display Replacement, Small ribbon cable connector: passo 7, immagine 2 di 3 HP EliteBook x360 830 G7 Display Replacement, Small ribbon cable connector: passo 7, immagine 3 di 3
    • Pull the small, bronze "Brighton" ribbon cable connector from the tan connection base.
  8. HP EliteBook x360 830 G7 Display Replacement, Separate the display housing from the computer: passo 8, immagine 1 di 1
    • If you can move your display's housing away from the computer, then you have successfully detached your display and can replace it.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 90
Tutti i Tempi: 1,857
