HP EliteBook x360 1030 G3 Fan Replacement
Introduzione
Vai al passo 1If your laptop is overheating and there is no fan noise, it may be in need of a fan replacement. Follow these steps to do so.
Cosa ti serve
Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
Remove the remaining four 7.3 mm screws using the same screwdriver.
Use a Phillips #1 screwdriver to remove the four 3.5 mm screws near the middle of the fan assembly.
Use the same screwdriver to remove the remaining five 3.9 mm screws.
Altre 4 persone hanno completato questa guida.
